Page 2 of 11 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 121
Thread: Mss-sp valves and fittings
  1. I need MSS SP 75 latest addition...plz help me..
    HI Achmad Nur Eddin
    Quote Originally Posted by AnandV View Post
    HI Achmad Nur Eddin
    Hi Anand V , How are you
  6. Links are expired
    Dear Sir
    All the links for MSS SP standards collection have expired. It would be very kind of you, if you can spare sometime and upload all the standards one more time.
    Thanking you in advance
  7. Dear Sir,
    All files r expired. It would be great from your side if u upload them again.
    Thank you very much.
  9. #18
    sulabh_87 & jigneshdesai
    OK but be patient. I'll upload partially
  10. #19
    MSS SP-6 - Standard finishes of contact faces of pipe flange & connecting of valves -2007.pdf 200.22 KB
    MSS SP-25 - Marking System-1997.pdf 1.88 MB
    MSS SP-42 150LB Corrossion Resist Gate,Globe,Angle,Check Valve -1999 .pdf 397.8 KB
    MSS SP-43 - Wrought stainless steel buttwelding fitting 2001.pdf 594.95 KB
    MSS SP-44 - Steel Pipeline Flange-2001.pdf 1.45 MB
    MSS SP-45 - ByPass and drain connection -2003.pdf 570.91 KB
    MSS SP-51 - Class 150LW Corrosion Resistant Flanges and Cast Flanged Fittings 2000.pdf 679.58 KB
    MSS SP-53 - Magnetic Particle Examination Method 1990.pdf 328.75 KB
  11. #20
    can some body combine all these standards in one file and than upload. I shall be very thankful.
    Muhammad Khurram
  12. #21
    Achmad Nur Eddin
    Thank you for your post
  13. Dear Sir,
    Thank you very mucj for your quick response.
  14. Hopefully you will upload the rest of the collection also.
    Thank you again.
  16. Dear Sir,
    Thank You Very Much.
    Regards.
  1. Replies: 59
    Last Post: 12-15-2018, 11:37 AM
  2. Crane TP-410. "Flow of Fluids through valves, fittings, and pipes
    By nocion_2h in forum Pipeline And Fluid Flow
    Last Post: 05-20-2018, 09:32 PM
  3. Crane - Flow of Fluids Through Valves, Fittings, and Pipe
    Last Post: 05-20-2018, 09:23 PM
  4. Replies: 0
    Last Post: 05-18-2013, 06:36 PM
  5. Flow of Fluids Through Valves, Fittings, and Pipe
    By azheee in forum Pipeline And Fluid Flow
    Last Post: 04-19-2011, 05:04 AM
