Page 2 of 12 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 140
Thread: Astm standards
  1. Re: Astm standards
    Hello Elefank, can you please send me ASTM D2047 standard ?
    Thanks, pRIMUS
    Re: Astm standards
    yeah i know your post says ASTM, but i just wanted to try and ask for these standards maybe you might have
    AS 2278
    UL 147
    UL 1291
    ANSI Z21.72
    JSIS 2147 & 2148
    BS EN 1205:2001
    GPA 2140-97
    HSNOCOP 46
    COP 54
    ASME VIII
    DOT 2P
  5. Re: Astm standards
    Construction Quality Control Procedures (Mechanical, Civil, Electrical)
  6. #16
    Re: Astm standards
    Pls share ASTM A671 / A671M - 13.
    Need urgent! Thanks in advange!
  7. #17
    Re: Astm standards
  9. #18
    Re: Astm standards
    Need ASTM A671 / A671M - 13!
    Pls share here. Thanks in advance!
  10. Re: Astm standards
    hi
    Some ASTM Standard, may be you want them !!
    ASTM D2122-2004 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    ASTM D2122-2004-2 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2122-2004-3 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2412-2008 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
    [link Point to another website Only the registered members can access] ASTM D2412-2008-2 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
    [link Point to another website Only the registered members can access] ASTM D2412-2008-3 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
    [link Point to another website Only the registered members can access] ASTM D2657-2007 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2657-2007-2 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2657-2007-3 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D3350-2008 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
    [link Point to another website Only the registered members can access] ASTM D3350-2008-2 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
    [link Point to another website Only the registered members can access] ASTM D3350-2008-3 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
    [link Point to another website Only the registered members can access] ASTM F412-2009 : Standard Terminology Relating to Plastic Piping Systems
    [link Point to another website Only the registered members can access] ASTM F412-2009-2 : Standard Terminology Relating to Plastic Piping Systems
    [link Point to another website Only the registered members can access] ASTM F412-2009-3 : Standard Terminology Relating to Plastic Piping Systems
    [link Point to another website Only the registered members can access] ASTM F477-2008- Part 1 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
    [link Point to another website Only the registered members can access] ASTM F477-2008- Part 2 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
    [link Point to another website Only the registered members can access] ASTM F477-2008- Part 3 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
    [link Point to another website Only the registered members can access] ASTM F1759-2004-Part 1 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
    [link Point to another website Only the registered members can access] ASTM F1759-2004-Part 2 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
    [link Point to another website Only the registered members can access] ASTM F1759-2004-Part 3 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
    [link Point to another website Only the registered members can access] ASTM_D_2122_(2010) : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM_D_2466_(2013) : Standard Specification for Poly Vinyl Chloride (PVC) Plastic Pipe Fittings, Schedule 40
    [link Point to another website Only the registered members can access] ASTM_D1598_(2009) : Standard Test Method for Time-to-Failure of Plastic Pipe Under Constant Internal Pressure
    [link Point to another website Only the registered members can access] ASTM_D1784_(2011) : Standard Specification for Rigid Poly Vinyl Chloride (PVC) Compounds and Chlorinated Poly Vinyl Chloride (CPVC) Compounds
  11. Re: Astm standards
    If it was useful Say thanks
  12. Re: Astm standards
    Links are broken...
  13. #22
    Nov 2010
    Algiers, ALGERIA
    Re: Astm standards
    Copy and paste on Google (web search engine) the following sentence:
    parsethylene-kish.com ASTM
    You will find many pdf documents.
    If you download and find it useful, just click on Thanks button !
    Visit and become a member of
    Welding Engineering & Inspection group
    Here:
  14. Re: Astm standards
    if you can't download , inform me
  16. #24
    Re: Astm standards
    Hello,
    Can you please share me the following ASTM
    ASTM D4404 - 10
    Many Thanks
  1. Replies: 13
  2. ASTM Standards
    By Mohamed in forum Materials Science &Corrosion
    Last Post: 06-15-2018, 12:54 AM
  3. ASTM Standards
    By mohsenkalantar in forum Materials Science &Corrosion
    Last Post: 11-15-2017, 09:53 PM
  4. Astm ndt standards
    By inconel in forum Mechanical Engineering
    Last Post: 10-19-2015, 04:48 AM
  5. Need the following ASTM standards
    By SA_FETY in forum Safety And Environment
    Last Post: 11-08-2011, 05:32 AM
