HEI Tech Sheets
Tube Tech Sheets
• Tech Sheet #129: Common NDE Tube Test Methods
• Tech Sheet #126: Accepted Practices for Packaging
• Tech Sheet #132: Comparison of OD and ID Eddy-Current Inspection of Tubing
• Tech Sheet #134: Heat Treatment of Tubes for Condenser, Feedwater Heater, and Shell & Tube Heat Exchangers
• Tech Sheet #135: A Comparison of Welded & Seamless Heat Exchanger Tubing
Shell & Tube Heat Exchanger Tech Sheets
• Tech Sheet #133: Basics of Shell & Tube Heat Exchangers
• Tech Sheet #137: Heat Exchanger Cladding
Feedwater Heater Tech Sheets
• Tech Sheet #128: Typical Feedwater Heater Cold Start-Up
• Tech Sheet #127: Basics of Closed Feedwater Heaters
• Tech Sheet #106: Specification of Tube Hole Sizes and Tolerances for Support and Baffle Plates
Vacuum Technology Tech Sheets
• Tech Sheet #130: Vacuum Condenser Drainage - Proper Design & Installation Guide
• Tech Sheet #110: Vacuum Systems: Understanding a Key Component of a Modern Power Plant
• Tech Sheet #107: Frequently Asked or Interesting Vacuum System Questions
• Tech Sheet #104: Ejector Throttling
• Tech Sheet #103: Ejector Discharge Pressure
Condenser Tech Sheets
• Tech Sheet #136: Condenser Hotwells
• Tech Sheet #131: Vacuum Breaker Valve
• Tech Sheet #125: Condenser Tube Cleaning
• Tech Sheet #124: Relief Valves vs. Rupture Discs
• Tech Sheet #123: Steam Inlet Expansion Joints
• Tech Sheet #122: Condenser Modular Replacement vs.Retube
• Tech Sheet #117: Waterbox Coating
• Tech Sheet #113: Condenser Basics
• Tech Sheet #101: Operational Alert on Steam Dumps
• HEI Typical Specification for Steam Surface Condensers Appendix A
• HEI Surface Condenser Data Sheet Appendix H
Deaerator Tech Sheets
• Tech Sheet #121: Vacuum Relief
• Tech Sheet #120: Steam Pressure Control Valves
• Tech Sheet #119: Safety and Relief Valves
• Tech Sheet #118: Level Control
• Tech Sheet #114: Deaerator Accessories
• Tech Sheet #112: Technical Discussion on Pressure Vessel Post Weld Heat Treatment
• Tech Sheet #111: Radiographic Testing (RT) Deaerator Vessels
• Tech Sheet #108: Magnetic Particle Testing in New Deaerators
• Tech Sheet #105: Deaerator Troubleshooting Guide
Missing #109, it was not downloadable
