Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 13 to 24 of 27
Thread: Problem Running ECLIPSE from PETREL
  1. #13
    Re: Problem Running ECLIPSE from PETREL
    Quote Originally Posted by Alphino View Post
    At which point exactly, you stuck ?
    1)Did you set your computer name in the license file ? (SERVER computerName ANY 8888 ) you need to change the ComputerName in here to your computer name )
    2)Paste the error message you get in here !
    3)does your license is only valid for a specific MAC address or it is valid for any system ? ( SERVER computerName ANY 8888 , Does your fist line in license look like line before? can you see "ANY" i it ? )
    Check these points and let me know
    licene eclipse is any 1700 and license petrel is only valid for a specific mac address. The first line in license "SERVER this_host 183da248acd8". Can you have me solve it?
    No one even Said a simple Thank you for the last post! so I make it brief this time.
    The Solution is very Simple . We install a "Virtual" Network Card and we would change this virtual Mac address.Note that you can install as many virtual Network Card and change their Mac address each of each of your license.One for eclipse another one for Petrel and the other one for Mepo and so on.
    This is specially helpful in situation in with you are connected to a network and if you and your colleague change your "Physical network Card" address you will got Duplicate network message error and the IT guy might get angry at you for messing up its network.So by using virtual network address you are on the safe side and you can both run the Petrel and still be connected to the same Network.
    Anyway, Here is the steps you should follow to install a "Virtual Network Card"
    1- Google on how to install a virtual card
    2- Change its Mac address
    3 -Enjoy it
    4- ÇÒ ÏæÓÊÇä Çå ˜ÓÛŒ ãÔ˜á ÏÇÔÊ ÛŒÇã ÎÕæÕÛŒ ÈÒÇÑå ˜å ˜Çãá ÈÑÇÔ ÊæÖÛŒÍ ÈÏã
    3 -Enjoy it
    4- ÇÒ ÏæÓÊÇä Çå ˜Óí ãÔ˜á ÏÇÔÊ íÇã ÎÕæÕí ÈÒÇÑå ˜å ˜Çãá ÈÑÇÔ ÊæÖíÍ ÈÏã
  6. #16
    Hi friends
    Hope everything goes well with you
    I have provided a huge collection of newest petroleum software like: Petrel 2013.3, Eclipse 2013.1, Geoframe 2012, Paradigm 2011.3, Olga 7.2, OSP4.0.3, Mepo 4.2, Techlog 2013.2, RoXar RMS 2013.1, Ecrin 4.2.07, CMG 2013.1, S/M/T K/ingdom 8.8, Rokdoc 6.0.0.107, Desicion Space Desktop r5000.8.1.1, Drillworks 5000.8.1.1, Openworks r5000.8.1, VIP-Nexus 5000.4.4.0, Skua Gocad 2011.3, IPM 8.0, PetroMod 2013.1, Interactive Petrophysics 4.1, Openflow 2012.2, Pipesim 2013.1, Que$tor 3013Q1, FractPro 2013, Vista 13, Jason 8.4, GeoGraphix Discovery 2013, and so many other things ...
    if anybody need Please contact me I will share with you. Also I need some applications hope you can kindly help me.
    My E-mail is: slbsoft33@gmail.com
    Cheers.
  7. Re: Problem Running ECLIPSE from PETREL
    Thank you Junay & Alphino
  9. Re: Problem Running ECLIPSE from PETREL
    Please I need Eclipse 2010.1 License for ANY Mac address to run it with Eclipse Urgent Pleaaaaaaaaaaaaaaaaase
  10. Re: Problem Running ECLIPSE from PETREL
  11. Re: Problem Running ECLIPSE from PETREL
    please I need lic file for ANY mac address fo eclipse 2010 help me help you > if my problem got solved ill give ******* petrel 2013 link and youtube video to setup please
  12. Re: Problem Running ECLIPSE from PETREL
    Asalaam o Aalkium,
    Kindly help me out to register the eclipse 2015. I have OS W7-64bit. If you have any version of eclipse with ***** working with 64bit kindly let me know. I will be very thankful to you.
  13. #22
    I have a problem running Visage and eclipse on Petrel. Please find attached the error message.
    I will appreciate any assistance from anyone
  14. Re: Problem Running ECLIPSE from PETREL
    Dear Alphino,
    I have both eclipse and petrel with two different MAC ID in their licenses, how can I make it work and run eclipse from petrel please. when I run eclipse petrel does not work and have to change to petrel MAC ID then petrel works and eclipse stop working. thanks in advance for your help.
  16. Re: Problem Running ECLIPSE from PETREL
    Alan45,
    install (virtnet) network adaptor, it enables you to make a separate ID for each.
    Aows K. Mohammad
  1. ECLIPSE2009.2 from PETREL2011 Running Problem
    By m.darweesh in forum Reservoir
    Last Post: 05-30-2013, 03:54 PM
  2. Eclipse 300 problem
    By Rafster in forum Reservoir
    Last Post: 04-30-2013, 02:11 AM
