Page 2 of 2 FirstFirst 1 2
Results 13 to 19 of 19
Thread: Hysys Air Stream
  1. #13
    Saturate extension with hysys 2006.5
    Attached Files Attached Files
    thank you suchart. it does not work with hysys 2006.5. i got the following messages:
    Image Type: COM
    The entry point "DllRegisterServer" could not be found.
    FATAL ERROR:
    Registration of the HYSYS extension saturate..dll failed.
    it requires MSVBM50.DLL which is not included in hysys 2006.5
    Quote Originally Posted by suchart View Post
    Jan 2009
    somewhere on the earth
    I think it works fine with all version
  6. #16
    can you check if you have MSVBM50.DLL file in your hysys directory and if you have it can you share the file? thanks.
  7. #17
    Jan 2009
    Dear mobek
    I searched all my computer but I didn't find MSVBM50.DLL
  9. #18
    Thank you motaleby. just forget it. It's supposed to be under system32 dir; i managed to find the file and install it in my pc yet i could not register the saturate extension.
    Best wishes, mobek
  10. #19
    Jan 2009
    Re: Hysys Air Stream
    Conclusion:
    You should use Psychometric Charts to find (kg H2O)/ (kg Air), you can determine this ratio by 2 known parameter of "Dry Bulb Temp, Wet Bulb Temp, Relative Humidity, Humidity Ratio and Enthalpy". The below site explains how to obtain the desired parameter from psychometric charts or simply use the uploaded G&P software:
    Then go to the composition tab in HYSYS and change basis into "Mass Fraction" and enter the proper fraction which obtained from the charts or software.
    Good Luck
  1. Article: Hysys Air Stream
    By motaleby in forum Home Articles
    Last Post: 06-18-2011, 07:04 PM
