Page 2 of 11 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 126
Thread: Caesar II 5.1 installation on Windows Vista/7
  1. Dear Mamali,
    Thanks. Good jobs.
    Best regard=)
  3. Quote Originally Posted by mamali View Post
    Hi there,
    You can simply install Caesar II 5.1 on Windows Vista and Seven 32bit with following procedure. Working 100% percent, tested by myself on Vista/7/7 installed on a virtual machine.
    Do it step by step exactly as noted below and you'll be surprised how easy is that. If you already tried to install with no luck you'll have to uninstall whatever you installed and clean up your system32 folder from 795F1F82.hasp.
    1- Download hdd32.exe from:
    [link Point to another website Only the registered members can access] 2- Run hdd32.exe.
    3- Turn off your anti-virus program.
    4- Run CaesarII 5.1 setup to insrall the software. Select default values for installation. Select green for Key installation. DO NOT restart at the end.
    5- Copy 795F1F82.hasp to Windows system32 folder.
    6- Right-Click on LND Emulator, select run as administrator.
    7- Click install just once and then close the application.
    8- Restart your computer.
    All done,
    Enjoy Caesar II 5.1 on your Windows 7/Vista.
    mr mamali, can I use this procedure for windows 7 home premium 64 bit?
  5. "Hi Dear All,
    I very much appreciate if anyone can help me to install the CII 5.1.
    I've Windows professional 64 bit and already installed the Windows XP mode/virtual PC 64 bit but am not able to get the CII running. I guess my v5.1 is bundled for 32 bit OS.
    thanks in advance"
    I think that was not clear, I should have said; it's Windows 7 professional 64 bit.
    Your advice, on how to run CII v5.10 on Windows 7-64 bit, is appreciated.
  6. #16
    Dear Mamali
    we have problem with my installation
    after we do above n run emulator
    have problem n display "opening hardlockfilter...................: eror 6
  7. #17
    Dear Mamali,
    Actualy my OS is win 7 utimate 32 bit
    after we finish follow your instruction and run the emulator
    on the monitor display opening hardlockfilter(location master of installer): error 6
    please help me
  9. #18
    Dear All,
    As I said before, you can only run CII 5.1 on 32bit system.
    I myself have installed and tested that and you should hve no problem doing same. For any problem, you may uninstall the software and clean up your system from Caesar and start all over again.
    Mamali
  10. Quote Originally Posted by mamali View Post
    Hi there,
    All done,
    Mamali,
    Thanks for the installation procedure.
    I have tried it and it work.
  11. Quote Originally Posted by NasA View Post
    Dear Mamali
    I got this before..
    Uninstal emulator, then install again
    hope it will work for you..
  12. #21
    Dear All,
    Ok Everything under control
    Thanks All
  13. Hi Buddy,
    Anyone have link to download "PDMS to CAESAR II" please?
  14. Error 7 coming after installation
    Hi
    I have installed the program as per the instructions but when I start the program I get error message
    "Error 7: HASP HL Key not found, or NetHL licenses all in use."
    Any suggestions or advice how to fix that.
    Thanks in advance...
  16. Quote Originally Posted by mamali View Post
    Hi there,
    All done,
    just for 7 with 32 bits right?
    how about 7 with 64 bits? have you found a solver ?
    or other member have found a solver
