Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 52
Thread: Aspenone 7.2 installation instructions for win7 32/64bit (not using windows xp mode)
  1. Hey Nour,
    I want you to repeat installing the license, but this time try standalone.. restart and try it..
    if it doesnt work
    uninstall Aspen, and delete it all left over folders in
    program files
    program files/common files
    remove from registery
    disable UAC (User Account Control)
    [link Point to another website Only the registered members can access] restart
    install license again for standalone this time
    install Aspen engineering
    Standard install (install in default location C:\programfiles(X86)\Aspentech) recommended
    Working files folder also defult (C:\ProgramData\Aspentech)
    Next, Skip user name and password/doamin
    install hysys
    restart
    enable UAC
    try Hysys
    check pdf in 1st post also (dont think u need it)
    i gave up nothing works
  5. u must be doin something wrong mate, i installed it again last night for a friend of mine,, and worked just fine on win7 home edition 32bit
  6. #16
    what is diffrent from ur installation
    1- when install msql server i select mixed autherization , and windows autherization anther time and both donot work
    2- when promot to ask for user name and pass i skip , but when runn the program [ failed to establish connection + unable to aquire the licence ]
    3- when disabled UAC the prgrame failed to continue set up [setup failed]
  7. I had the same problem with my friends computer..
    I uninstalled MSQL then restarted
    Uninstalled AspenOne V7.2
    Restart
    Cleaned Temp folder
    Cleaned registry (make sure to backup ur system drive, if u delete anything wrong ur windows wont start)
    Restart
    Removed Aspen folder from program files and program data, also from common files in program files
    I did the same for Hyprotech folder
    restart.
    Installed the license for standalone
    Installed MSQL russian version
    Installed Hysys
    Restarted
    Run hysys
  9. Uploading the MSQL am using now for u, will be up in 1 hr
  10. I use this MSQL
    h tt p://h otfile.com/dl/116198115/4b7d227/SQLEXPR_RUS.rar.html
  11. #20
    excellent contribution. many thanks
  12. Guys..
    I will not answer any questions anymore ,, if u ask with private messages.
    I am getting lots of questions and most are the same..
    If u have a question please post in the thread so I dont need to answer the same question everytime to a differnet member please ask here and I will answer it as soon as I can
  13. #22
    i tried every step in this video and as always nothing works
    h ttp://www.youtube.com/watch?v=WHifH7rHWW8&feature=related
    may be the problem in my widows version or antivirus ??? i dont know what is wrong ??
    i followed it step by step and nothing works
  14. please go to control panel and check if u have one or 2 msql services and which 1 is running
  16. #24
    only one
    which i inserted as shown in the video provided
  1. Upgrading Windows 32bit to 64bit
    By doombuggy in forum Computer & Internet
    Last Post: 05-20-2013, 11:15 AM
