Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 13 to 24 of 46
Thread: Applying the ASME Codes - Plant Piping and Pressure Vessels
  1. Please upload again
    I am so sad .Rapidshare blocked the files just 7 days to remove them
  3. Reupload
    Could you please reupload those files. Rapid share blocked them.
    Thank you.
    hi...can someone upload these files on other link..... getting following error on Rapidshare..
    Error
    This file is suspected to contain illegal content and has been blocked. After the file has been blocked for 7 days it will automatically be deleted, if the block is not removed by RapidShare. For this reason, a download of this file is currently not possible.
  6. reupload the files please
  7. If anyone have this book please reupload again.
    Thank you
  9. #18
  10. #19
    Oct 2008
    The Netherlands
    Blog Entries
    14
    I do not a method for treating a rectangulangular nozzle.
    But unless you use FEA ..then you can start with and equivalent nozzle with a diameter equal to the the rectangle large size..
    You can treat the nozzle compensation = area replacement with this equivalent diameter...
    For nozzle loads I believe the WRC 107 have a case for rectangular nozzle..
    Well good luck
  11. Thank you for reuploading on filefactory.
  12. The files are corrupt, or are having problems
  13. Please reupload. The rapishare links don't work and neither do the FileFactory links which were kindly uploaded by baibur. I've tried several times with the Filefactory links, and everytime it gives the error that there are "no free download slots available". Someone please reupload.
  14. #23
    Usman
    Thanks alot jazak allah
  16. #24
    Try This
  1. Pressure Vessels, the ASME Code Simplified
    Last Post: 11-12-2017, 12:47 AM
  2. Replies: 7
    Last Post: 09-04-2014, 10:13 AM
  3. Applying the ASME Code: Plant Piping and Pressure Vessels
    By Noppakhun in forum Mechanical Engineering
    Last Post: 06-21-2014, 06:42 AM
  4. Replies: 50
    Last Post: 06-30-2011, 05:22 AM
  5. ASME Section X FRP pressure vessels
    By Michael Min in forum Mechanical Engineering
    Last Post: 07-31-2010, 11:24 AM
