formulaes above need to be adjusted for drainage conditions that start from Sw=1. use S*=(Sw-Swir)/(1-Swir). You may need to iterate a bit on Swir for each data set - but you can use the lowest Sw in most cases. For sample 2 I used 0.28
No simply plots pc vs S* on a log-log plot seeking straight line trends ( for the exponents). We note some curvature at very high Sw - which again we tend to discount if "spin-up" a time offset effects impact experiment. Whats left is surprisingly OK. I get a slope of about -0.8 which implies a Lambda of 1.25 ( which is also reasonable)
I ended up fitting J*ScosT= 9.3*(S*)^-1/1.25 to the valid data. 2 out of 3 match quite well and the third is acceptable.
Sample 183291 plots up OK using Swir of 0.08.
now my question is who should be plot on x-axis and y-axis
secondly how you deduce exponent from log log plot as said above by you
second question is
what term are J*ScosT
and from where and how you deduce the exponent of your equation i.e -1/1.25
kindly share your idea in detail , i have tried a lot but unable to arrive at
