Hi,
The solution of this problem you will find on the web page[link Point to another website Only the registered members can access]
Hi,
Did you use VFP tables?
good day for everyone
Could you help me with issue of convergence
I build fine grid model which represent matrix block and fracture around. i filled fracture with CO2 and open connection between matrix and fracture to test gravity affect. But when i opened connection there is convergence problem
It is compositionam model with 8 components by the way. i think it is due to oscilation of Eclipse . Cuz when i open connection density of CO2 850 and density of oil 940. And Eclipse cant deferentiate between tho phases
I dont know how to use LIFACT for forcing this difference. Is there any other way how to help to Eclipse to deferentiate two phases near miscibility point?
model works up to opening connection perfect, without any problem
Hope to feel feedback from you
i cheked PVT and everything is ok there
I have uploaded data file
could you plz take a look at it.
-- Reference Case: Fracturation diffuse tempa rossa
-- CO2 OIL Gravity drainage
-- Created 28/05/2009
-- Projet Carbonate - Ecoulement polyphasique
RUNSPEC
TITLE
SINGLE POROSITY MONO BLOCK DRAINAGE OF CO2-OIL SYSTEM
METRIC
---- GRID
DIMENS
--NX NY NZ
28 28 56 /
-- Taille de Bloc 10.0 x 10.0 x 10.0
-- Taille Modèle 6.0 x 6.0 x 12.0
-- Modèle 1/4 Bloc Matriciel
-- NB Cell MATRICE : 25 x 25 x 50
-- DIP : 0.0°
-- Cellules MATRICE : 1 25 0 25 4 53
NONNC
---- PVT
WATER
COMPS
8 /
EOS
PR /
ENDSCALE
TABDIMS
-- NTSFUN NTPVT NSSFUN NPPVT NTFIP NRPVT
2 1 30 66 2 20 /
EQLDIMS
-- NTEQL NDPRVD NDRXVD NTTRVD NSTRVD
1 200 10 /
REGDIMS
--- FIPNUM FIPSET RESNUM FLUXNUM
2 1 1 2 2* 2 /
WELLDIMS
2 56 1 2 3 2 1 2 /
-- nwells ncompl groups wel/grp etag srtem mixt sepa
--NOSIM
UNIFIN
CO2SOL
UNIFOUT
NSTACK
150 /
MESSAGES
3* 10000 5* 10000/
START
1 'JAN' 2000/
GRIDOPTS
1* 2 /
GRID
NOECHO
INCLUDE
'INCLUDE/GRID_Bloc10x10x10_25Cel.Grdecl'/
ECHO
--Property of Fracture
BOX
1 28 1 28 1 56 /
PORO
43904*1 /
PERMX
43904*1e5 /
PERMZ
43904*1e3 /
NTG
43904*1 /
MULTPV
43904*10 /
ACTNUM
43904*1 /
MINPVV
43904*1e-11 /
COPY
'PERMX' 'PERMY'/
ENDBOX
--Porosity of Matrix
BOX
1 25 1 25 4 53 /
PORO
31250*0.3 /
PERMX
31250*100 /
PERMY
31250*100 /
PERMZ
31250*1 /
NTG
31250*1 /
MULTPV
31250*1 /
31250*1e-11 /
ENDBOX
EQUALS
OPERNUM 2 1 28 1 28 1 56 / -- HMP 0 Fractures
OPERNUM 1 1 25 1 25 4 53 / -- HMP 0 Matrix --> DIFFUSE fracture Kr Fracture
MULTREGT
1 2 0.000001 2* O /
INIT
EDIT
PROPS
SGFN
--Kr gas matrix drainage
--Sg Krg dr Pc o-g
0 0 0
0.1 0.01 0
0.2 0.04 0
0.3 0.09 0
0.4 0.16 0
0.5 0.25 0
0.6 0.36 0
0.7 0.49 0
0.8 0.64 0
0.9 0.81 0
1.0 1.0 0/ -- Edit of max Sg value (set to 1.0) for consistency with Swirr 0.0
0 0 0
0.1 0.1 0
0.2 0.2 0
0.3 0.3 0
0.4 0.4 0
0.5 0.5 0
0.6 0.6 0
0.7 0.7 0
0.8 0.8 0
0.9 0.9 0
1.0 1.0 0/ -- Linear Kr in fractures
SWFN
--Sw Krw Pc w-g dr
0 0 0
0.1 0.01 0
0.2 0.04 0
0.3 0.09 0
0.4 0.16 0
0.5 0.25 0
0.6 0.36 0
0.7 0.49 0
0.8 0.64 0
0.9 0.81 0
0 0 0
0.1 0.1 0
0.2 0.2 0
0.3 0.3 0
0.4 0.4 0
0.5 0.5 0
0.6 0.6 0
0.7 0.7 0
0.8 0.8 0
0.9 0.9 0
SOF3
--So Krow Krog
0.0 0.0 0.0
1.0 1.0 1.0/ -- Edit of last So value (set to 1.0) for consistency with Swirr 0.0
0.0 0.0 0.0
1.0 1.0 1.0/
EQUALS
SWL 0.0 1 28 1 28 1 56 / -- HMP 0 Fractures
SWL 0.0 1 25 1 25 4 53 / -- HMP 0 Matrix
--- Critical Water Saturation
COPY
SWL SWCR/
ADD
SWCR 0.05 1 25 1 25 5 54 / -- Matrix
SWCR 0.05 26 28 1 28 1 56 / -- FRACTURE BACK
SWCR 0.05 1 28 26 28 1 56 / -- FRACTURE RIGHT
SWCR 0.05 1 28 1 28 1 3 / -- FRACTURE TOP
SWCR 0.05 1 28 1 28 54 56 / -- FRACTURE BOTTOM
--- Critical Gas Saturation --> trapped gas saturation as no hysteresis
-- Set to 0.2*(1-Swconnate)
COPY
SWL SGCR 1 28 1 28 1 56 /
COPY
SWL SGU 1 28 1 28 1 56 /
MULTIPLY
SGU -1.0 1 28 1 28 1 56 /
ADD
SGU 1.0 1 28 1 28 1 56 /
-- Critical Oil in Water saturation
EQUALS
SOWCR 0.0 1 28 1 28 1 56 / -- HMP 0 Fractures
-- SOWCR 0.05 1 25 1 25 5 54 / -- HMP 0 MatrixSOWCR
-- Critical Oil in gas saturation
SOGCR 0.0 1 28 1 28 1 56 / -- HMP 0 Fractures
-- SOGCR 0.01 1 25 1 25 5 54 / -- HMP 0 MatrixSOWCR
ROCKOPTS
2* 'SATNUM' / -- Rock compressibility table as of SATNUM
ROCK
400 9.0E-5 / -- Matrix compressibility
400 4.5e-4 / -- Fractures compressibility (Matrix x5)
------------ PVT COMPOSITIONNEL 8 COMPOSANT -----
NOECHO
-- Peng-Robinson correction pour les grands facteurs acentriques
PRCORR
-- Standard conditions: T.p (units above)
STCOND
15.0 1.0 /
-- Initial Reservoir Temperature Deg C
RTEMP
85. /
-- changement des doefficients LBC par default (viscosite)
LBCCOEF
0.098853 0.051056 -0.014419 0.003933 0.0 /
-- User/Characterised Components
CNAMES
CO2 GAZ GPL FIOUL CN1 CN2 CN3 CN4 /
-- Critical temperatures (Deg K)
TCRIT
304.20 229.24 473.54 586.95 663.15 773.150 963.15 1773.15 /
-- Critical pressures (bara)
PCRIT
73.77 47.69 34.22 26.39 20.50 17.50 14.30 6.85 /
-- Critical volumes (m3/mol)
VCRIT
0.0939 0.0924 0.3082 0.4942 0.7563 1.125 1.830 7.000 /
--EQUIVALENT DE VO POUR BEST (m3/mol)
VCOMPACT
0.01966 0.0193467 0.0645309 0.1034757 0.1817 0.2413 0.3697 1.7305 /
-- Acentric factors
ACF
0.2250 0.0453 0.2327 0.3619 0.5500 0.6800 0.8600 0.9000 /
-- Molecular Weights (g/gmole)
MW
44.01 22.09 73.69 118.15 180.82 297.88 550.00 1617.00 /
--tension interfaciale
PARACHOR
78. 77. 190.0 270.0 500.0 900.0 1300.0 2000.0 /
BIC
0.00
0.11 0.11
0.13 0.016 0.000
0.12 0.100 0.000 0.000
0.10 0.110 0.000 0.000 0.00
0.10 0.120 0.000 0.000 0.00 0.00
0.10 0.020 0.000 0.000 0.00 0.00 0.00
--DEPTH CO2 GAZ GPL FIOUL CN1 CN2 CN3 CN4
ZMFVD
3700. 0.000 0.5446 0.0881 0.0822 0.0831 0.1944 0.0065 0.0011
3800. 0.000 0.524 0.089260 0.082102 0.083084 0.201294 0.015441 0.004819
4000. 0.000 0.450 0.093284 0.081765 0.082879 0.226106 0.047614 0.018352
4112. 0.000 0.300 0.126684 0.112023 0.105482 0.245000 0.090000 0.020811
4200. 0.000 0.19998 0.135673 0.118919 0.120539 0.264128 0.112982 0.047779
4300. 0.000 0.100 0.152647 0.133797 0.135620 0.258174 0.127005 0.092757
4400. 0.000 0.100 0.152647 0.133797 0.135620 0.258174 0.127005 0.092757
/ ---Zone PVT1
DENSITY
1* 1004. 1* /
--oil water gas
-- Water PVT Properties at Pref (Pref Bwref Cw Vis viscosibility=dVw/dP) :
PVTW
-- Pref Bw Cw Vw Cvw
-- BARSA RM3/SM3 1/BARS CPOISE 1/BARS
500.9 1.04 3.72E-05 0.25 5.85007E-05 /
SOLUBILITY
--PRESS GWR BW MUW CW
200. 27. 1.055 0.364 4.870E-05 /
------OPTION POUR CO2 Soluble dans L'eau
--RSWVD
--2030.0 0.079393 /
--DEPTH concentrationCO2/H2O
--- QC Kr curves & end-points
EPSDEBUG
-- IX1 IX2 JY1 JY2 KZ1 KZ2 SWITCH
1 1 1 1 2 2 0/----================================================== ==============
REGIONS
EQUALS
EQLNUM 1 1 28 1 28 1 56 / -- HMP 0 Fractures
SATNUM 2 1 28 1 28 1 56 / -- HMP 0 Fractures
SATNUM 1 1 25 1 25 4 53 / -- HMP 0 Matrix --> DIFFUSE fracture Kr Fracture
PVTNUM 1 1 28 1 28 1 56 / -- HMP 0 Fractures + MATRIX
COPY
'SATNUM' 'FIPNUM' /
SOLUTION
EQUIL
--Datum Pref W/O Pcow G/O PCgo Rsvsd Rvvsd Acc
4106 447 4175 0 3175 0 0 0 20 1 0 / -- Matrix 75 m above contact
RPTRST
'BASIC=2' PRES SWAT SGAS PSAT RS VOIL VGAS DENO DENG VISC CONV / --- Report initial state
FIELDSEP
1 20. 1. /
SUMMARY
RUNSUM
RGIP
ROIP
RPR
RWSAT
ROSAT
RGSAT
ROE
--Date
ELAPSED
TCPU
TCPUTS
TCPUDAY
NEWTON
TIMESTEP
RGFT
1 2/
ROFT
1 2/
RRPV
ROPV
BOSAT
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BOIP
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BBOIL
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BDENO
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BDENG
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BVOIL
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BVGAS
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BGSAT
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BGIPL
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
BBGAS
1 1 1 /
1 1 28 /
28 28 1 /
28 28 56 /
26 14 3 /
26 15 3 /
26 16 3 /
25 22 3 /
24 22 3 /
9 21 55 /
FCMPR
1 /
FCMPR
2 /
FCMPR
8 /
FXMFG
1 /
FYMFG
1 /
FODN
FOPT
FGIT
FVPR
FVIR
FODN
FGPR
FGOR
FOE
SCHEDULE
IMPLICIT
----- WELLS -----------
WELSPECS
PRODFRAC FRAC 1 28 4106 OIL 1* 1* SHUT /
INJCO2FR FRAC 28 1 4106 WATER 1* 1* SHUT 6* HMIW/
-- Well completion specification data:
COMPORD
PRODFRAC INPUT /
INJCO2FR INPUT /
COMPDAT
--Name I J K1 K2 Status Sat CCF diam KHU S D direc
PRODFRAC 1 28 1 56 OPEN 1* 0 0.1 0 0. 1* Z /
INJCO2FR 28 1 1 56 OPEN 1* 0 0.1 0 0. 1* Z /
WELLSTRE
PURECO2 1 7*0 /
WINJGAS
--- Well FluidType FLuidName
INJCO2FR STREAM PURECO2 /
-- Control data for production wells:
WCONPROD
-- Qres BHPmin
'PRODFRAC' OPEN RESV 4* 455 50 /
WCONINJE
-- QIres BHPmax
'INJCO2FR' GAS OPEN RESV 1* 455 500.0 /
TUNING
--TSINIT TSMAXZ TSMINZ TSMCHP TSFMAX TSFMIN TSFCNV TFDIFF THRUPT
--NEWTMX NEWTMN LITMAX
0.001 1 0.0001 0.10 1.2 0.2 0.1 /
40 1 150 /
RPTRST
'BASIC=2' PRES SOIL SGAS PSAT RS VOIL VGAS DENO DENG VISC CONV /
MULTREGT
1 2 1 /
TSTEP
10*0.001 9*0.01 4*0.1 10*1 10*1 /
--------------------------------------------------------- 20.5 DAYS
WCONPROD
-- Qres BHPmin
'PRODFRAC' SHUT RESV 4* 455 50 /
WCONINJE
-- QIres BHPmax
MULTREGT
1 2 1 /
TSTEP
5*0.1 8*0.25 10*0.5 4*1 /
--------------------------------------------------------- 3.5 DAYS
WELOPEN
PRODFRAC SHUT /
INJCO2FR SHUT /
MULTREGT
1 2 1000000 /
TSTEP
10*0.001 9*0.01 4*0.1 2*0.25 2*0.5 50*1 /
--------------------------------------------------------- 183 DAYS
END
this is the grid for that data file
