Page 18 of 23 FirstFirst ... 8 16 17 18 19 20 ... LastLast
Results 205 to 216 of 271
Thread: UL Standards Needed
  1. #205
    Re: UL Standards Needed
    Quote Originally Posted by C.Queiroz View Post
    All links to UL 1709 are dead.
    can someone help me??
    Please?
    Here you go...
  3. Re: UL Standards Needed
    Quote Originally Posted by Marty Thompson View Post
    Here you go...
    Thank you!
  5. Re: UL Standards Needed
    Here you go...
    Thank you!
  6. Re: UL Standards Needed
    Jempol 5 kanggo sampeam mas ahmad...
  7. #209
    please if any gentleman has UL 299- 2012 , UL 711 , UL 1803-2012 pdf
  9. What Are Dominion Auctions?
    Getting a empire fame of our own is an basic component of owning a business online. However, nowadays most of the renowned sphere names are either already registered or owned through some other business. This means that you need to invent up of originative territory names to collar noticed on the internet. This can sometimes be a challenging thing to do. In whatever way, the illustrious side to this is that most of the lands names that were already registered could have planned expired. It could be because the train may have closed down or the
  10. #211
    Re: What Are Dominion Auctions?
    Hello, I'm looking for UL-260. If somebady were kindly to share a apreciate very much.
    Thanks forever.
  11. #212
    Here you go... UL 260
  12. #213
    Thaks bro, here in México a lot of people specifies deluge valves with an hemeticity ANSI class VI and I wanted to correct that point on my documents and let the UL standard aplies as the only criteria for hermeticity of deluge valves for fire service.
    Best regards.
  13. #214
    And I'm now looking for the UL-218, because a provider is offering us a fire aquipment and is stating that his fire pump controller can't send more signals via Ethernet MODBUS-RTU because the UL standard prohibits the increment of signals from fire pump controller to a PLC of Fire System.
    So if somebody has that piece and wouldn't mind to share or give a hint about this item, it will be welcome!!
    Thaks a lot!
  14. #215
    I can't find the 218, but here is an article on it and 2 related control docs.
  16. Re: UL Standards Needed
    Dear colleagues,
    Does anybody have UL-262 available for sharing?
    Please please share this.
    All old links are not working.
  1. Standards needed
    By panthere0rose in forum Mechanical Engineering
    Last Post: 05-22-2015, 12:38 AM
  2. Iso standards needed
    By Onoma Epwnymo in forum Laboratory Measurements
    Last Post: 03-30-2013, 01:02 PM
  3. standards needed
    By mmanous13 in forum Mechanical Engineering
    Last Post: 09-04-2012, 03:18 AM
  4. Standards needed
    Last Post: 04-17-2012, 08:34 PM
  5. Jpi standards needed
    By setak in forum Materials Science &Corrosion
    Last Post: 08-06-2011, 12:15 AM
