Page 12 of 33 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Results 133 to 144 of 389
Thread: API Standard
  1. Hi folks...
    Looking for Material Selection guidelines for Sour Water Stripping Plants I found these references:
    1. NACE Technical Committee Report (TG 347), 2007 Draft, “Review and Survey of Alkaline Carbonate SCC in Refinery Sour Waters”
    2. API Publ.932-A and 932-B, 2002 & 2004
    3. API Publ.944, “1972 Survey of Materials Experience and Corrosion Problems in Sour Water Stripers” November 1974
    4. API Publ.948, “A Study of Variables That Affect the Corrosion of Sour Water Strippers,” May 1976
    5. API Publ.950, “Survey of Construction Materials and Corrosion in Sour Water Strippers ,” May 1976
    6. API Publ.927, “1972 Sour Water Stripping Survey Evaluation”, 1973
    7. API Publ.954, “Evaluation of Ammonia fixation components in actual refinery sour waters”, 1978
    But they must be old, Out-of-print or even withdrawn because I couldn't find them.... would anyone of you have a copy of any of these publications and is willing to share it?
    Thanks in advance
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Hi Friend I am also looking for the above book. Please share. Thanks in advance.
    Thanks a lot. Good luck!!!
    Could somebody upload following standards ? Thank you in advance
    API Recommended Practice 5UE, Recommended Practice for Ultrasonic
    Evaluation of Pipe Imperfections, Second Edition, June 2005
    API Specification 5LCP, Specification for Coiled Line Pipe, Second
    Edition, October 2006.
    API Standard 6A718, Nickel Base Alloy 718 (UNS N07718) for Oil and Gas
    Drilling and Production Equipment, 2nd Edition, December 2009
    API Specification 6DSS, Specification for Subsea Pipeline Valves, Second
    API RP 10B-2/ISO 10426-2, Recommended Practice for Testing Well Cements, 1st Edition, July 2005
    RP 13C, Recommended Practice on Drilling Fluids Processing Systems Evaluation, 3rd Edition, December 2004
    API Spec 17J/ISO 13628-2, Specification for Unbonded Flexible Pipe, Third Edition, July 2008
    ANSI/API RP 19D, Measuring the Long-term Conductivity of Proppants, 1st Edition, May 2008
    API RP 65, Cementing Shallow Water Flow Zones in Deep Water Wells, 1st Edition, September 2002
  6. #136
    Can I have API standard for all Lifting Gears?
  7. #137
    Inspections for all lifting gear and mooring equipment, full version.
  9. #138
    API Standard 677 2nd Ed. July 1997 - General Purpose Gear Units For Petroleum, Chemical, and Gas Industry Services.pdf
    API Standard 613 5th Ed. Feb. 2003 - Special Purpose Gear Units for Petroleum, Chemical and Gas Industry Services.pdf
    API RP 2I 2nd Ed. Nov. 1996 - In-Service Inspection of Mooring Hardware for Floating Drilling Units.pdf
  10. #139
    Thank you for the Inspection of Mooring. is there any stated inspection of s****les webbing ect.?
  11. hi, please share API RP941, THANKS
  12. #141
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Hi, Gilbert,
    PLease find the link to API 941:
    However this is a bit old edition. This the best that could be provided.
    Quote Originally Posted by gilbert View Post
  13. #142
    Hello Friends I need the standard
    API Std 1104 (R2010)
    Welding of Pipelines and Related Facilities - 20th Edition, Includes Errata 1 (2007) and 2 (2008)
    Related Facilities
    Pipeline Segment
    API STANDARD 1104
    TWENTIETH EDITION, OCTOBER 2005
    ERRATA / ADDENDUM, JULY 2004
    ERRATA 2, DECEMBER 2008
    Reaffirmed, APRIL 2010
    Please ask if someone has please pass me the link to download
    From now on my Acknowledgements
  14. #143
    Quote Originally Posted by npsrinivasarao View Post
    Hi, Gilbert,
    API RP 941 7th Ed. Aug. 2008 - Steels for Hydrogen Service at Elevated Temperatures and Pressures in Petroleum Refineries and Petrochemical Plants.pdf
    API - Technical Report 941 Sept. 2008 - The Technical Basis Document for API RP 941.pdf
  16. #144
    Quote Originally Posted by Mr Welder View Post
    Related Facilities
    Pipeline Segment
    API STANDARD 1104
    Since it is reaffirmed, 2008 should be the same.
    API Standard 1104 20th Ed. Oct. 2005 Errata1:Addendum July 2007, Errata 2 Dec. 2008 - Welding of Pipelines and Related Facilities Full.pdf
  1. standard
    By maksimilijan in forum Safety And Environment
    Last Post: 08-17-2011, 08:44 AM
  2. Ped standard
    By tobbe in forum Pipeline And Fluid Flow
    Last Post: 07-27-2011, 11:54 AM
  3. Need the following IS Standard (indian standard) urgently
    By SA_FETY in forum Safety And Environment
    Last Post: 07-06-2011, 09:02 AM
  4. api standard
    By hosain yasi in forum Oil And Gas Process
    Last Post: 12-17-2009, 05:23 PM
  5. Jis standard piping standard
    By muthukarthi in forum Mechanical Engineering
    Last Post: 12-10-2009, 03:19 AM
