Dear resteam .. please sendt to : doni26.doni@gmail.com
Thank you
Thank you
why don't u share here
Hi i have collected some activation codes ; plz try if one of them worked with etap 12.6
aq+u&dSFMJSKNASskzdN9exK/A@iWA24&Tx/
fGfbh3n6Mks8tB4YkGCv5D+J2CGeVBKKaYyE
AfW#$jscCxH+ZJY3$?YYd#GbHpAysh5BBvKq
DW4zBT$8gti@BrvhXxDvaLvcmQ7H8XwfDRhW
%RZRSSNwC%Qrn%hRvCpRCw8+CvfpBx4tzfMu
U53ra2F9b#qZ9EFVATGfhEB7%ZEFiydBGxL&
Z@8cUuS5w#nytVgCfvvccA%tDDu4jD6aNb?K
mahfouz can you gieve me the carck please?lixflores90@hotmail.com
Dear friends carck of etap 11 works with versions 12.5 and 12.6 but u should install virtual machine before applying the carck; I did it and it works 100% but the problem we need an valid activation code, I hope some one upload an valid activation code
Cheers
Dear Friend,
There is no ----- for ETAP 12.5 & 12.6 in internet. If you really need this software, you'll can send me email: eng.soft2015@gmail.com
For Stable version with full function, I always available here: eng.soft2015@gmail.com
Hi restesam,
if you proceeded so far, I think i should give you another clue.
Just apply any activation code like 0000000000 and see at one point it fails to check. ----- it and it will accept any code and some modules will be available. Then go on changing the codes till all are open. This is hit and trial method. Once you get all options available, Etap will start running, but with some nagg message. Then search for the similar position in other files and ----- them. All Done. In this manner you can run any version of ETAP. It took me almost 6 hours to make 12.5 work. Then just 1 hr job for for 12.6.
cheers
Dear cadguy
i dont get your point. could u plz provide me with a detaiedl explanation
Hi,
as I checked your forum activity I believe you have some basic knowledge of reversing. So just check that etapsdb.dll where it returns error for our licen string. Just make the comparison to zero and make it pass. It is somewhere near SPerm lib.
cheers
