Thread: Finite Element Analysis for the Thin Pressure Vessels
    Dear Members,
    HAY?
    When we design a pressure vessel as per ASME SEC-VIII Div, 1 , there may be any requirement of FEA of different components of Pressure vessel???When???In what cases??Generaly when FEA OF Vessels required?Please elaborate me and help me inthis regard.
    Best Regards
    DEEP
  3. I dont understand the question.
    You dont need FEA, you can do the calculations by hand or some other software.
  5. If there is a component on your pressure vessel that can't be designed using the standard ASME VIII rules then FEA can be used for designing this more complex part. ASME VIII Div 2 describes the required FEA procedure.
  6. dear deep79pk
    read carefully the following appendix:
    ASME PVB Section VIII. div.2. Appendix 4. 4-120 one program that useable for pressure vessel component FEM design : ALGOR FEMRPO
    good luck
  1. free finite element engineering design and analysis software
    By hpesoft in forum Computer & Internet
    Last Post: 12-01-2013, 06:35 PM
  2. Finite Element Analysis - EBooks Collection
    By mrk in forum Mechanical Engineering
    Last Post: 02-29-2012, 07:26 AM
