Results 1 to 12 of 62
Thread: pipeline calculations
    Dear all,
    Can you solve a simple problem for me,
    I have 1" dia pipe of 100m length , at the inlet Air is at 5kg/cm2 pressure, I need to know the maximum flow of air (m3/hr) through the pipe, outlet pressure is 2 kg/cm2 temperature is 38C.
  2. Smile
    Quote Originally Posted by amitavbh View Post
    Dear all,
    answer of the question from AYAZUDDIN
    In such condition the velocity of air increase up to the rule of thumb suggested velocity 66 ft/sec,
    analysis express the velocityis 122 ft/sec but in that scenario max. flow would be 56.5 m3/hr, which
    increase in pipe due to small line size which is 112.4 m3/hr. as far as my suggestion of current situation
    you must increase ur line size because velocity is very high
  1. Replies: 215
    Last Post: 08-10-2018, 06:00 AM
  2. Piping and pipeline calculations manual
    By aap in forum Mechanical Engineering
    Last Post: 09-07-2015, 11:07 AM
  3. Replies: 20
    Last Post: 09-07-2015, 11:04 AM
  4. Article: pipeline calculations
    By kunal_5683 in forum Home Articles
    Last Post: 05-20-2010, 10:57 AM
