Thread: Tubular Connection Cleaning Befor Inspection
  1. Tubular Connection Cleaning Befor Inspection
    I use a petrol as an effective means to clean the tubular connections, but due to the seriousness and high susceptibility to flammable and the dangers of fumes I want to Change it with other material or other means to clean the grease before inspection and of this I want the brethren who are working on the same development proposals in this regard
    White spirits works good. Diesel is the best. But if you want to be on the safe side then use simple green degreaser.
    Feb 2011
    Islamabad, Pakistan
    Diesel is the best option.
    May 2011
    Caracas, Venezuela, Venezuela
    Hello to all of you.
    I'm a specialist in pipes for the oil industry and Diesel must not be used. Diesel forms a film in the surface of the connections and prevents a correct attachment of the running dope to the threads, risking the correct running and sealability of the connection.
    If you want to remove it completely follow the next steps.
    Cold weather (near or under 0 Celsius):
    As you can't use liquid water in order to remove the dope, you must use steam, so apply hot steam to the connection using a steam hydro jet and try to remove the dope in excess using a brush with plastic (non metallic) bristles.
    Warm weather: It's easier to remove it completely.
    1.- Use a water hydro jet to remove the excess of storage compound in pin and box.
    2.- Brush gently the connections, using a brush with plastic (non metallic) bristles, with a soap solution (the same soap that you use to clean your clothes).
    3.- Remove the soap solution again with a water hydro jet.
    It's important to notice that storage grease must be removed before running beacuse it doesn't have sealing and lubricanting properties. Also, storage compound must be replaced at least once in a year in order to inspect the connections.
    I hope that it will help you.
    FFF
  1. Replies: 3
    Last Post: 06-07-2017, 03:26 PM
  2. Replies: 11
    Last Post: 08-08-2016, 11:07 AM
  3. Replies: 0
    Last Post: 01-16-2014, 07:22 AM
  4. Ask : Civil Inspection and Test Plan / Field Inspection and Form
    By Cikni in forum Civil & Structural Engineering
    Last Post: 08-25-2013, 05:47 PM
  5. Tubing connection interchangeable with PH6 connection
    By dunglan in forum Drilling And Workover
    Last Post: 04-26-2011, 08:58 AM
