As requested by Manahan Rudolf
AWS B2.1-1-205-2007 Standard Welding Procedure Specification (SWPS) forShielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, E6010 (Vertical Uphill) Followed by E7018 (Vertical Uphill), As-Welded or PWHT Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
AWS B2.1.1.205-2007 Standard WPS of SMW Carbon Steel 1-8 thru 1 1-2 in.Vertical Uphill & Vertical Uphill & PWHT.pdf 0.265 MB
AWS B2.1-1-206-96 (R2007) Standard Welding Procedure Specification (SWPS) for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, E6010 (Vertical Downhill) Followed by E7018 (Vertical Uphill), As-Welded or PWHT Condition, Primarily Pipe Applications – Site License (ANSI STANDARD)
AWS B2.1.1.206-2007 Standard WPS of SMW Carbon Steel 1-8 thru 1 1-2 in.Vertical Uphill & Vertical Downhill & PWHT.pdf 0.267 MB
