I am working on a few data points where I need to calculate the corrected API (@ 60F) from an observed API which was taken at a different temperature for crude oil. I also need to calcualte corrected volume as well for which I believe I understand I need the VCF (Volume Correction Factors).
I understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume I" contains Table 5A: Generalized Crude Oils, Correction of Observed API Gravity to API Gravity at 60°F and Table 6A: Generalized Crude Oils, Correction of Volume to 60°F Against API Gravity.
I also understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume X" contains Background, Development, and Computer Documentation and that Volume X actually has the algorithms and equations published for calculating and approximating all of the tables published in the 12 volume Adjunct set.
I don't know how many pages there are to Tables 5A and 6A in Volume 1 but that is what I believe I need. Even better would be the algorithms/equations that generate these particular tables for which I understand is published in Volume 10.
Can someone help me with this??
I only need this data for a one time set of calculations..
Thanks to whoever can help me with this!!
Greg
