Creating the Plant Pipe Code
W.N. Weaver, PE
Pipes codes are used to standardize piping practices in a facility, to ensure each fluid is conveyed in the appropriate materials, to control piping costs and to ensure plant safety.There are multiple pipe codes in use in the various industries involved with pipe
Creating proper pipe codes for your facility is generally a combined effort between
engineering, operations and maintenance. Where available piping, corrosion and welding engineers should be included in the design group.It is not necessary to start the creation process with a blank sheet of paper; starting from an existing national code simplifies the process and gives everyone a view of what the finished product should look like and contain. Before we go further let us see why we even need a pipe code. It’s generally easier to produce an appropriate document if we understand the reason we need the document in the first place.
Sasikumar
