Thread: ISO Collection 127/300:ISO/TC 113 - Hydrometry
    Standards and projects under the direct responsibility of ISO/TC 113 Secretariat
    ISO 772:2011 Hydrometry -- Vocabulary and symbols
    ISO 4369:1979 Measurement of liquid flow in open channels -- Moving-boat method
    ISO 9196:1992 Liquid flow measurement in open channels -- Flow measurements under ice conditions
    ISO 9555-1:1994 Measurement of liquid flow in open channels -- Tracer dilution methods for the measurement of steady flow -- Part 1: General
    ISO 9555-3:1992 Measurement of liquid flow in open channels -- Tracer dilution methods for the measurement of steady flow -- Part 3: Chemical tracers
    ISO 9555-4:1992 Measurement of liquid flow in open channels -- Tracer dilution methods for the measurement of steady flow -- Part 4: Fluorescent tracers
    ISO 9825:2005 Hydrometry -- Field measurement of discharge in large rivers and rivers in flood
    ISO/TS 25377:2007 Hydrometric uncertainty guidance (HUG)
    Velocity area methods
    ISO 748:2007 Hydrometry -- Measurement of liquid flow in open channels using current-meters or floats
    ISO 1070:1992 Liquid flow measurement in open channels -- Slope-area method
    ISO 1070:1992/Amd 1:1997 Liquid flow measurement in open channels -- Slope-area method
    ISO 1100-2:2010 Hydrometry -- Measurement of liquid flow in open channels -- Part 2: Determination of the stage-discharge relationship
    ISO 2425:2010 Hydrometry -- Measurement of liquid flow in open channels under tidal conditions
    ISO 6416:2004 Hydrometry -- Measurement of discharge by the ultrasonic (acoustic) method
    ISO 9123:2001 Measurement of liquid flow in open channels -- Stage-fall-discharge relationships
    ISO/TR 9824:2007 Hydrometry -- Measurement of free surface flow in closed conduits
    ISO/TS 15768:2000 Measurement of liquid velocity in open channels -- Design* selection and use of electromagnetic current meters
    ISO 15769:2010 Hydrometry -- Guidelines for the application of acoustic velocity meters using the Doppler and echo correlation methods
    ISO 18365:2013 Hydrometry -- Selection* establishment and operation of a gauging station
    ISO/TR 24578:2012 Hydrometry -- Acoustic Doppler profiler -- Method and application for measurement of flow in open channel
    Flow measurement structures
    ISO 1438:2008 Hydrometry -- Open channel flow measurement using thin-plate weirs
    ISO 1438:2008/Cor 1:2008 Hydrometry -- Open channel flow measurement using thin-plate weirs
    ISO 3846:2008 Hydrometry -- Open channel flow measurement using rectangular broad-crested weirs
    ISO 3847:1977 Liquid flow measurement in open channels by weirs and flumes -- End-depth method for estimation of flow in rectangular channels with a free overfall
    ISO 4359:2013 Flow measurement structures -- Rectangular* trapezoidal and U-shaped flumes
    ISO 4360:2008 Hydrometry -- Open channel flow measurement using triangular profile weirs
    ISO 4362:1999 Hydrometric determinations -- Flow measurement in open channels using structures -- Trapezoidal broad-crested weirs
    ISO 4371:1984 Measurement of liquid flow in open channels by weirs and flumes -- End depth method for estimation of flow in non-rectangular channels with a free overfall (approximate method)
    ISO 4374:1990 Liquid flow measurement in open channels -- Round-nose horizontal broad-crested weirs
    ISO 4377:2012 Hydrometric determinations -- Flow measurement in open channels using structures -- Flat-V weirs
    ISO 8333:1985 Liquid flow measurement in open channels by weirs and flumes -- V-shaped broad-crested weirs
    ISO 8368:1999 Hydrometric determinations -- Flow measurements in open channels using structures -- Guidelines for selection of structure
    ISO 9826:1992 Measurement of liquid flow in open channels -- Parshall and SANIIRI flumes
    ISO 9827:1994 Measurement of liquid flow in open channels by weirs and flumes -- Streamlined triangular profile weirs
    ISO 13550:2002 Hydrometric determinations -- Flow measurements in open channels using structures -- Use of vertical underflow gates and radial gates
    ISO 14139:2000 Hydrometric determinations -- Flow measurements in open channels using structures -- Compound gauging structures
    ISO 26906:2015 Hydrometry -- Fishpasses at flow measurement structures
    Instruments* equipment and data management
    ISO 1088:2007 Hydrometry -- Velocity-area methods using current-meters -- Collection and processing of data for determination of uncertainties in flow measurement
    ISO 2537:2007 Hydrometry -- Rotating-element current-meters
    ISO 3454:2008 Hydrometry -- Direct depth sounding and suspension equipment
    ISO 3455:2007 Hydrometry -- Calibration of current-meters in straight open tanks
    ISO 4366:2007 Hydrometry -- Echo sounders for water depth measurements
    ISO 4373:2008 Hydrometry -- Water level measuring devices
    ISO 4375:2014 Hydrometry -- Cableway systems for stream gauging
    ISO 6420:2016 Hydrometry -- Position fixing equipment for hydrometric boats
    ISO/TR 11328:1994 Measurement of liquid flow in open channels -- Equipment for the measurement of discharge under ice conditions
    ISO 11655:1995 Measurement of liquid flow in open channels -- Method of specifying performance of hydrometric equipment
    ISO 24155:2016 Hydrometry -- Hydrometric data transmission systems -- Specification of system requirements
    Sediment transport
    ISO/TS 3716:2006 Hydrometry -- Functional requirements and characteristics of suspended-sediment samplers
    ISO 4363:2002 Measurement of liquid flow in open channels -- Methods for measurement of characteristics of suspended sediment
    ISO 4364:1997 Measurement of liquid flow in open channels -- Bed material sampling
    ISO 4364:1997/Cor 1:2000 Measurement of liquid flow in open channels -- Bed material sampling
    ISO 4365:2005 Liquid flow in open channels -- Sediment in streams and canals -- Determination of concentration* particle size distribution and relative density
    ISO 6421:2012 Hydrometry -- Methods for assessment of reservoir sedimentation
    ISO 9195:1992 Liquid flow measurement in open channels -- Sampling and analysis of gravel-bed material
    ISO/TR 9212:2015 Hydrometry -- Methods of measurement of bedload discharge
    ISO 11329:2001 Hydrometric determinations -- Measurement of suspended sediment transport in tidal channels
    ISO/TR 11651:2015 Estimation of sediment deposition in reservoirs using one dimensional simulation models
    ISO 11657:2014 Hydrometry -- Suspended sediment in streams and canals -- Determination of concentration by surrogate techniques
    Ground water
    ISO/TR 13973:2014 Artificial recharge to groundwater
    ISO/TR 14685:2001 Hydrometric determinations -- Geophysical logging of boreholes for hydrogeological purposes -- Considerations and guidelines for making measurements
    ISO 14686:2003 Hydrometric determinations -- Pumping tests for water wells -- Considerations and guidelines for design* performance and use
    ISO 21413:2005 Manual methods for the measurement of a groundwater level in a well
    ISO/TR 21414:2016 Hydrometry -- Groundwater -- Surface geophysical surveys for hydrogeological purposes
    ISO/TR 23211:2009 Hydrometry -- Measuring the water level in a well using automated pressure transducer methods
    missing are:
    links:
    or
    Re: ISO Collection 127/300:ISO/TC 113 - Hydrometry
    update:
    added missing/new:
    ISO/TR 19234:2016 Hydrometry -- Low cost baffle solution to aid fish passage at triangular profile weirs that conform to ISO 4360
    missing list:
    update:
    BQ or missing:
    new missing list:
    ISO 1438:2017 Hydrometry -- Open channel flow measurement using thin-plate weirs
    ISO 4359:2013/AMD 1:2017 Flow measurement structures -- Rectangular* trapezoidal and U-shaped flumes
    full list 29.12.2017.
    ISO 6416:2017 Hydrometry -- Measurement of discharge by the ultrasonic transit time (time of flight) method
    ISO 9123:2017 Hydrometry -- Stage-fall-discharge relationships
    ISO/TR 9210:2017 Hydrometry -- Measurement in meandering river and in streams with unstable boundaries
    ISO/TS 15768:2000 Measurement of liquid velocity in open channels -- Design, selection and use of electromagnetic current meters
    ISO 18365:2013 Hydrometry -- Selection, establishment and operation of a gauging station
    ISO 4359:2013 Flow measurement structures -- Rectangular, trapezoidal and U-shaped flumes
    ISO 4359:2013/AMD 1:2017 Flow measurement structures -- Rectangular, trapezoidal and U-shaped flumes
    ISO 18481:2017 Hydrometry -- Liquid flow measurement using end depth method in channels with a free overfall
    ISO 4365:2005 Liquid flow in open channels -- Sediment in streams and canals -- Determination of concentration, particle size distribution and relative density
    ISO 14686:2003 Hydrometric determinations -- Pumping tests for water wells -- Considerations and guidelines for design, performance and use
    the missing:
  1. CEN Standards Collection 153/370-CEN TC 318-Hydrometry
    Last Post: 05-29-2017, 02:33 AM
