Results 1 to 12 of 84
Thread: NEPLAN v5.5.6 solved
    The software fully works* instructions are in Spanish and Chinese* even I speak that language was a little difficult to understand steps.
    Only the key is to copy the demo licence file and rename it. And it works
    Instructions to install are on Spanish but software is multilingual
    Re: NEPLAN v5.5.6 solved
    Quote Originally Posted by himmelstern View Post
    PROCEDIMIENTO DE INSTALACIÓN - INSTALLATION PROCEDURE
    Instalar el software de manera normal - Install the software in the normal way
    Ir a la carpeta donde se instaló el programa - Go to the folder where the program was installed
    Realizar una copia del archivo - Make a copy of the file : NepDemoLicense.dll
    Y cambiarle de nombre por - And change its name to : NepLicense.dll
    Luego abrir el programa les aparecerá - Then open the program will appear:
    AquÃ* deben seleccionar la primera opción: Iniciar NEPLAN en modo de licencia normal…
    Here you must select the first option: Start NEPLAN in normal license mode ...
    Luego Pegar donde dice código de activación - Then Paste where it says activation code: oJF8W3Nb9z@q@+/CipPf<do8*vp83kZDzJ3
    Thanks to google translate ......
    Quote Originally Posted by PemulA View Post
    Instalar el software de manera normal - Install the software as regular installation to finish
    Ir a la carpeta donde se instaló el programa - Go to the folder location where the program was installed
    Y cambiarle de nombre por - And rename to : NepLicense.dll in the same location
    Luego abrir el programa les aparecerá - Then open the software will appear:
    AquÃ* deben seleccionar la primera opción: Click on start NEPLAN at regular licence mode at the first option
    Luego Pegar donde dice código de activación - Then Paste activation code: oJF8W3Nb9z@q@+/CipPf<do8*vp83kZDzJ3 or others at serial txt
  5. Re: NEPLAN v5.5.6 solved
    Thanks very much for sharing. Any one with NEPLAN cde file format for automating network import from GIS data into NEPLAN?
  1. Neplan 5.5.4
    By restesam in forum Electrical & Power Engineering
    Last Post: 05-20-2017, 10:54 PM
  2. Neplan 5.5.5
    By fernando05 in forum Electrical & Power Engineering
    Last Post: 02-18-2017, 05:13 PM
  3. Neplan 5.5.3
    By serdds in forum Electrical & Power Engineering
    Last Post: 12-12-2015, 02:56 PM
  4. Neplan
    By kazes in forum Electrical & Power Engineering
    Last Post: 04-19-2013, 08:44 PM
