Page 1 of 2 1 2 LastLast
Results 1 to 12 of 14
Thread: CEN Standards Collection 181/370: CEN TC 127-Fire Safety In Buildings
    full list:
    EN ISO 1182:2010 Reaction to fire tests for products - Non-combustibility test (ISO 1182:2010)
    CEN/TS 1187:2012 Test methods for external fire exposure to roofs
    EN 1363-1:2012 Fire resistance tests - Part 1: General Requirements
    EN 1363-2:1999 Fire resistance tests - Part 2: Alternative and additional procedures
    ENV 1363-3:1998 Fire resistance tests - Part 3: Verification of furnace performance
    EN 1364-1:2015 Fire resistance tests for non-loadbearing elements - Part 1: Walls
    EN 1364-2:1999 Fire resistance tests for non-loadbearing elements - Part 2: Ceilings
    EN 1364-3:2014 Fire resistance tests for non-loadbearing elements - Part 3: Curtain walling - Full configuration (complete assembly)
    EN 1364-4:2014 Fire resistance tests for non-loadbearing elements - Part 4: Curtain walling - Part configuration
    EN 1365-1:2012 Fire resistance tests for loadbearing elements - Part 1: Walls
    EN 1365-1:2012/AC:2013 Fire resistance tests for loadbearing elements - Part 1: Walls
    EN 1365-2:2014 Fire resistance tests for loadbearing elements - Part 2: Floors and roofs
    EN 1365-3:1999 Fire resistance tests for loadbearing elements - Part 3: Beams
    EN 1365-4:1999 Fire resistance tests for loadbearing elements - Part 4: Columns
    EN 1365-5:2004 Fire resistance tests for loadbearing elements - Part 5: Balconies and walkways
    EN 1365-6:2004 Fire resistance tests for loadbearing elements - Part 6: Stairs
    EN 1366-1:2014 Fire resistance tests for service installations - Part 1: Ventilation ducts
    EN 1366-2:2015 Fire resistance tests for service installations - Part 2: Fire dampers
    EN 1366-3:2009 Fire resistance tests for service installations - Part 3: Penetration seals
    EN 1366-4:2006+A1:2010 Fire resistance tests for service installations - Part 4: Linear joint seals
    EN 1366-5:2010 Fire resistance tests for service installations - Part 5: Service ducts and shafts
    EN 1366-6:2004 Fire resistance tests for service installations - Part 6: Raised access and hollow core floors
    EN 1366-7:2004 Fire resistance tests for service installations - Part 7: Conveyor systems and their closures
    EN 1366-8:2004 Fire resistance tests for service installations - Part 8: Smoke extraction ducts
    EN 1366-9:2008 Fire resistance tests for service installations - Part 9: Single compartment smoke extraction ducts
    EN 1366-10:2011 Fire resistance tests for service installations - Part 10: Smoke control dampers
    EN 1366-12:2014 Fire resistance tests for service installations - Part 12: Non-mechanical fire barrier for ventilation ductwork
    EN 1634-1:2014 Fire resistance and smoke control tests for door and shutter assemblies, openable windows and elements of building hardware - Part 1: Fire resistance test for door and shutter assemblies and openable windows
    EN 1634-2:2008 Fire resistance and smoke control tests for door, shutter and openable window assemblies and elements of building hardware - Part 2: Fire resistance characterisation test for elements of building hardware
    EN 1634-3:2004 Fire resistance and smoke control tests for door and shutter assemblies, openable windows and elements of building hardware - Part 3: Smoke control test for door and shutter assemblies
    EN 1634-3:2004/AC:2006 Fire resistance and smoke control tests for door and shutter assemblies, openable windows and elements of building hardware - Part 3: Smoke control test for door and shutter assemblies
    EN ISO 1716:2010 Reaction to fire tests for products - Determination of the gross heat of combustion (calorific value) (ISO 1716:2010)
    EN ISO 9239-1:2010 Reaction to fire tests for floorings - Part 1: Determination of the burning behaviour using a radiant heat source (ISO 9239-1:2010)
    EN ISO 11925-2:2010 Reaction to fire tests - Ignitability of products subjected to direct impingement of flame - Part 2: Single-flame source test (ISO 11925-2:2010)
    EN ISO 11925-2:2010/AC:2011 Reaction to fire tests - Ignitability of products subjected to direct impingement of flame - Part 2: Single-flame source test - Technical Corrigendum 1 (ISO 11925-2:2010/Cor 1:2011)
    EN 13238:2010 Reaction to fire tests for building products - Conditioning procedures and general rules for selection of substrates
    EN 13381-1:2014 Test methods for determining the contribution to the fire resistance of structural members - Part 1: Horizontal protective membranes
    EN 13381-2:2014 Test methods for determining the contribution to the fire resistance of structural members - Part 2: Vertical protective membranes
    EN 13381-3:2015 Test methods for determining the contribution to the fire resistance of structural members - Part 3: Applied protection to concrete members
    EN 13381-5:2014 Test methods for determining the contribution to the fire resistance of structural members - Part 5: Applied protection to concrete/profiled sheet steel composite member
    EN 13381-6:2012 Test methods for determining the contribution to the fire resistance of structural members - Part 6: Applied protection to concrete filled hollow steel columns
    ENV 13381-7:2002 Test methods for determining the contribution to the fire resistance of structural members - Part 7: Applied protection to timber members
    EN 13381-8:2013 Test methods for determining the contribution to the fire resistance of structural members - Part 8: Applied reactive protection to steel members
    EN 13381-9:2015 Test methods for determining the contribution to the fire resistance of structural members - Part 9: Applied fire protection systems to steel beams with web openings
    EN 13501-1:2007+A1:2009 Fire classification of construction products and building elements - Part 1: Classification using data from reaction to fire tests
    EN 13501-2:2007+A1:2009 Fire classification of construction products and building elements - Part 2: Classification using data from fire resistance tests, excluding ventilation services
    EN 13501-3:2005+A1:2009 Fire classification of construction products and building elements - Part 3: Classification using data from fire resistance tests on products and elements used in building service installations: fire resisting ducts and fire dampers
    EN 13501-4:2007+A1:2009 Fire classification of construction products and building elements - Part 4: Classification using data from fire resistance tests on components of smoke control systems
    EN 13501-5:2005+A1:2009 Fire classification of construction products and building elements - Part 5: Classification using data from external fire exposure to roofs tests
    EN 13501-6:2014 Fire classification of construction products and building elements - Part 6: Classification using data from reaction to fire tests on electric cables
    EN 13823:2010+A1:2014 Reaction to fire tests for building products - Building products excluding floorings exposed to the thermal attack by a single burning item
    EN ISO 13943:2010 Fire safety - Vocabulary (ISO 13943:2008)
    EN 14135:2004 Coverings - Determination of fire protection ability
    EN 14390:2007 Fire test - Large-scale room reference test for surface products
    EN 15080-8:2009 Extended application of results from fire resistance tests - Part 8: Beams
    EN 15080-12:2011 Extended application of results from fire resistance tests - Part 12: Loadbearing masonry walls
    CEN/TS 15117:2005 Guidance on direct and extended application
    EN 15254-2:2009 Extended application of results from fire resistance tests - Non-loadbearing walls - Part 2: Masonry and Gypsum Blocks
    EN 15254-4:2008+A1:2011 Extended application of results from fire resistance tests - Non-loadbearing walls - Part 4: Glazed constructions
    EN 15254-5:2009 Extended application of results from fire resistance tests - Non-loadbearing walls - Part 5: Metal sandwich panel construction
    EN 15254-6:2014 Extended application of results from fire resistance tests - Non-loadbearing walls - Part 6: Curtain walling
    EN 15254-7:2012 Extended application of results from fire resistance tests - Non-loadbearing ceilings - Part 7: Metal sandwich panel construction
    EN 15269-1:2010 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies, including their elements of building hardware - Part 1: General requirements
    EN 15269-2:2012 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies, including their elements of building hardware - Part 2: Fire resistance of hinged and pivoted steel doorsets
    EN 15269-3:2012 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies, including their elements of building hardware - Part 3: Fire resistance of hinged and pivoted timber doorsets and openable timb
    EN 15269-5:2014 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies, including their elements of building hardware - Part 5: Fire resistance of hinged and pivoted metal framed glazed doorsets and
    EN 15269-7:2009 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies, including their elements of building hardware - Part 7: Fire resistance for steel sliding doorsets
    EN 15269-10:2011 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies including their elements of building hardware - Part 10: Fire resistance of steel rolling shutter assemblies
    EN 15269-20:2009 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies, including their elements of building hardware - Part 20: Smoke control for hinged and pivoted steel, timber and metal framed gl
    CEN/TS 15447:2006 Mounting and fixing in reaction to fire tests under the Construction Products Directive
    EN 15725:2010 Extended application reports on the fire performance of construction products and building elements
    EN 15725:2010/AC:2012 Extended application reports on the fire performance of construction products and building elements
    EN 15882-1:2011 Extended application of results from fire resistance tests for service installations - Part 1: Ducts
    EN 15882-2:2015 Extended application of results from fire resistance tests for service installations - Part 2: Fire dampers
    EN 15882-3:2009 Extended applications of results from fire resistance tests for service installations - Part 3: Penetration seals
    EN 15882-4:2012 Extended application of results from fire resistance tests for service installations - Part 4: Linear joint seals
    CEN/TS 16459:2013 External fire exposure of roofs and roof coverings - Extended application of test results from CEN/TS 1187
    missing standards:
    [link Point to another website Only the registered members can access] or
    Re: CEN Standards Collection 181/300: CEN TC 191-Fixed Firefighting Systems
    great effort
    many thanks
  5. Re: CEN Standards Collection 181/300: CEN TC 127-Fire Safety In Buildings
    Beautiful collection!
    Thank You very much!!
  6. Re: CEN Standards Collection 181/300: CEN TC 127-Fire Safety In Buildings
  7. #5
    no updates, missing list:
    EN 16733:2016 Reaction to fire tests for building products - Determination of a building product's propensity to undergo continuous smouldering
    new links:
    or
  9. #6
    Re: CEN Standards Collection 181/340: CEN TC 127-Fire Safety In Buildings
    just more missing list:
    EN 13501-2:2016 Fire classification of construction products and building elements - Part 2: Classification using data from fire resistance tests, excluding ventilation services
    EN 13501-4:2016 Fire classification of construction products and building elements - Part 4: Classification using data from fire resistance tests on components of smoke control systems
    EN 13501-5:2016 Fire classification of construction products and building elements - Part 5: Classification using data from external fire exposure to roofs tests
    CEN/TR 16988:2016 Estimation of uncertainty in the single burning item test
    new links:
    or
  10. #7
    update:
    CEN/TS 15117:2005 Guidance on direct and extended application - added missing standard
    CEN/TS 15447:2006 Mounting and fixing in reaction to fire tests under the Construction Products Directive - added missing standard
    EN 15725:2010/AC:2012 Extended application reports on the fire performance of construction products and building elements - EN version
    missing are:
    links:
    or
  11. #8
    Re: CEN Standards Collection 181/350: CEN TC 127-Fire Safety In Buildings
    update:
    EN 13501-5:2016 Fire classification of construction products and building elements - Part 5: Classification using data from external fire exposure to roofs tests - added missing standard thankx to Amjad Malik
    EN 16733:2016 Reaction to fire tests for building products - Determination of a building product's propensity to undergo continuous smouldering - added missing standard thankx to Amjad Malik
    missing list:
    updated links:
    or
  12. #9
    update:
    EN 13501-2:2016 Fire classification of construction products and building elements - Part 2: Classification using data from fire resistance tests, excluding ventilation services - added missing standard
    EN 13501-4:2016 Fire classification of construction products and building elements - Part 4: Classification using data from fire resistance tests on components of smoke control systems - added missing standard
    CEN/TR 16988:2016 Estimation of uncertainty in the single burning item test - added missing standard
    missing one now is:
    EN 15269-5:2014+A1:2016 Extended application of test results for fire resistance and/or smoke control for door, shutter and openable window assemblies, including their elements of building hardware - Part 5: Fire resistance of hinged and pivoted metal framed glazed doorsets and
    links:
    or
  13. #10
    update:
    added missing standard:
    EN 15269-5:2014+A1:2016 Extended application of test results for fire resistance and/or smoke control for door* shutter and openable window assemblies* including their elements of building hardware - Part 5: Fire resistance of hinged and pivoted metal framed glazed doorsets and
    sector complete
    link:
  14. Re: CEN Standards Collection 181/370: CEN TC 127-Fire Safety In Buildings
    CEN/CLC/TC 4 - Services for fire safety and security systems ?!
  16. #12
    nothing changed* new link:
  1. Replies: 14
    Last Post: 08-07-2018, 06:33 AM
  2. Replies: 6
    Last Post: 12-28-2017, 04:07 PM
  3. Replies: 9
    Last Post: 06-08-2017, 04:43 PM
  4. CEN Standards Collection 152/370: CEN TC 369-Candle Fire Safety
    Last Post: 05-29-2017, 02:08 AM
  5. Verifying Fire Safety Design in Sprinklered Buildings
    By f81aa in forum Safety And Environment
    Last Post: 05-17-2011, 01:46 PM
