Results 1 to 12 of 100
Thread: CEN Standards Collection 1/370: CEN TC 121 - Welding & Allied Processes
    Re: CEN Standards Collection 1/350: CEN TC 121 - Welding & Allied Processes
    update:
    better quality of the following standards:
    EN ISO 3580:2011 Welding consumables - Covered electrodes for manual metal arc welding of creep-resisting steels - Classification (ISO 3580:2010)
    EN ISO 3690:2012 Welding and allied processes - Determination of hydrogen content in arc weld metal (ISO 3690:2012)
    EN ISO 14171:2016 Welding consumables - Solid wire electrodes, tubular cored electrodes and electrode/flux combinations for submerged arc welding of non alloy and fine grain steels -- Classification (ISO 14171:2016)
    EN ISO 14341:2011 Welding consumables - Wire electrodes and weld deposits for gas shielded metal arc welding of non alloy and fine grain steels - Classification (ISO 14341:2010)
    EN ISO 14344:2010 Welding consumables - Procurement of filler materials and fluxes (ISO 14344:2010)
    EN ISO 16834:2012 Welding consumables - Wire electrodes, wires, rods and deposits for gas shielded arc welding of high strength steels - Classification (ISO 16834:2012)
    EN ISO 17777:2016 Welding consumables - Covered electrodes for manual metal arc welding of copper and copper alloys - Classification (ISO 17777:2016)
    EN ISO 18275:2012 Welding consumables - Covered electrodes for manual metal arc welding of high-strength steels - Classification (ISO 18275:2011)
    EN ISO 19288:2016 Welding consumables - Solid wire electrodes, solid wires and rods for fusion welding of magnesium and magnesium alloys - Classification
    EN ISO 17683:2015 Ships and marine technology - Ceramic weld backing for marine use (ISO 17683:2014)
    EN ISO 18279:2003 Brazing - Imperfections in brazed joints (ISO 18279:2003)
    EN ISO 15012-4:2016 Health and safety in welding and allied processes - Equipment for capture and separation of welding fume - Part 4: General requirements (ISO 15012-4:2016)
    EN ISO 17916:2016 Safety of thermal cutting machines (ISO 17916:2016)
    EN ISO 22825:2012 Non-destructive testing of welds - Ultrasonic testing - Testing of welds in austenitic steels and nickel-based alloys (ISO 22825:2012)
    EN ISO 10042:2005 Welding - Arc-welded joints in aluminium and its alloys - Quality levels for imperfections (ISO 10042:2005)
    EN ISO 10042:2005/AC:2006 Welding - Arc-welded joints in aluminium and its alloys - Quality levels for imperfections (ISO 10042:2005)
    EN ISO 12932:2013 Welding - Laser-arc hybrid welding of steels, nickel and nickel alloys - Quality levels for imperfections (ISO 12932:2013)
    EN ISO 14744-1:2008 Welding - Acceptance inspection of electron beam welding machines - Part 1: Principles and acceptance conditions (ISO 14744-1:2008)
    EN ISO 9692-3:2016 Welding and allied processes - Recommendations for joint preparation - Part 3: Metal inert gas welding and tungsten inert gas welding of aluminium and its alloys (ISO 9692-3:2016)
    EN ISO 15609-6:2013 Specification and qualification of welding procedures for metallic materials - Welding procedure specification - Part 6: Laser-arc hybrid welding (ISO 15609-6:2013)
    EN ISO 15614-6:2006 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 6: Arc and gas welding of copper and its alloys (ISO 15614-6:2006)
    EN ISO 15614-12:2014 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 12: Spot, seam and projection welding (ISO 15614-12:2014)
    EN ISO 15614-13:2012 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 13: Upset (resistance butt) and flash welding (ISO 15614-13:2012)
    EN ISO 15614-14:2013 Specification and qualification of welding procedures for metallic materials - Welding procedure test - Part 14: Laser-arc hybrid welding of steels, nickel and nickel alloys (ISO 15614-14:2013)
    EN ISO 17658:2015 Welding - Imperfections in oxyfuel flame cuts, laser beam cuts and plasma cuts - Terminology (ISO 17658:2002)
    EN ISO 17662:2016 Welding - Calibration, verification and validation of equipment used for welding, including ancillary activities (ISO 17662:2016)
    CEN ISO/TR 17844:2004 Welding - Comparison of standardised methods for the avoidance of cold *****s (ISO/TR 17844:2004)
    CEN ISO/TR 18166:2016 Numerical welding simulation - Execution and documentation
    EN ISO 5178:2011 Destructive tests on welds in metallic materials - Longitudinal tensile test on weld metal in fusion welded joints (ISO 5178:2001)
    EN ISO 9016:2012 Destructive tests on welds in metallic materials - Impact tests - Test specimen location, notch orientation and examination (ISO 9016:2012)
    EN ISO 12996:2013 Mechanical joining - Destructive testing of joints - Specimen dimensions and test procedure for tensile shear testing of single joints (ISO 12996:2013)
    EN ISO 17641-1:2004 Destructive tests on welds in metallic materials - Hot *****ing tests for weldments - Arc welding processes - Part 1: General (ISO 17641-1:2004)
    CEN ISO/TR 17641-3:2005 Destructive tests on welds in metallic materials - Hot *****ing tests for weldments - Arc welding processes - Part 3: Externally loaded tests (ISO/TR 17641-3:2005)
    EN ISO 5182:2016 Resistance welding - Materials for electrodes and ancillary equipment (ISO 5182:2016)
    EN ISO 8430-1:2016 Resistance spot welding - Electrode holders - Part 1: Taper fixing 1:10 (ISO 8430-1:2016)
    EN ISO 8430-2:2016 Resistance spot welding - Electrode holders - Part 2: Morse taper fixing (ISO 8430-2:2016)
    EN ISO 8430-3:2016 Resistance spot welding - Electrode holders - Part 3: Parallel shank fixing for end thrust (ISO 8430-3:2016)
    EN ISO 10447:2015 Resistance welding - Peel and chisel testing of resistance spot and projection welds (ISO 10447:2015)
    EN ISO 14270:2016 Resistance welding - Destructive testing of welds - Specimen dimensions and procedure for mechanized peel testing resistance spot, seam and embossed projection welds (ISO 14270:2016)
    EN ISO 14272:2016 Resistance welding - Destructive testing of welds - Specimen dimensions and procedure for cross tension testing of resistance spot and embossed projection welds (ISO 14272:2016)
    EN ISO 14273:2016 Resistance welding - Destructive testing of welds - Specimen dimensions and procedure for tensile shear testing resistance spot and embossed projection welds (ISO 14273:2016)
    EN ISO 14323:2015 Resistance spot welding and projection welds - Destructive testing of welds - Specimen dimensions and procedure for impact shear test and cross-tension testing (ISO 14323:2015)
    EN ISO 14373:2015 Resistance welding - Procedure for spot welding of uncoated and coated low carbon steels (ISO 14373:2015)
    EN ISO 14554-1:2013 Quality requirements for welding - Resistance welding of metallic materials - Part 1: Comprehensive quality requirements (ISO 14554-1:2013)
    EN ISO 14554-2:2013 Quality requirements for welding - Resistance welding of metallic materials - Part 2: Elementary quality requirements (ISO 14554-2:2013)
    EN ISO 18278-2:2016 Resistance welding - Weldability - Part 2: Evaluation procedures for weldability in spot welding (ISO 18278-2:2016)
    the missing list is:
    EN ISO 3677:2016 Filler metal for soldering and brazing - Designation (ISO 3677:2016)
    EN ISO 15618-1:2016 Qualification testing of welders for underwater welding - Part 1: Hyperbaric wet welding (ISO 15618-1:2016)
    EN ISO 17638:2016 Non-destructive testing of welds - Magnetic particle testing (ISO 17638:2016
    new link:
    Thanks a lot, a nice extensive list.
  1. Replies: 9
    Last Post: 07-10-2019, 01:40 PM
  2. ISO Collection 11/300:ISO/TC 44 - Welding and allied processes
    Last Post: 05-30-2019, 03:20 PM
  3. DIN SPEC of NA 092 - Welding and allied processes
    Last Post: 01-09-2017, 02:06 AM
  4. ISO 6947:2011 Welding and allied processes -- Welding positions
    By KVladimir in forum Mechanical Engineering
    Last Post: 10-18-2015, 06:04 PM
  5. EN 14610 - Welding and allied processes
    Last Post: 04-09-2012, 09:19 AM
