can you share these documents?
1. Evaluation of Boiler and Heat Recovery Steam Generator Chemical Cleaning Waste Treatment Options
2. Proceedings: EPRI International Conference on Corrosion in Power Plants
3. Boiler Chemical Cleaning Waste Management Manual
4. Guidelines for Makeup Water Treatment
5. Comprehensive Cycle Chemistry Guidelines for Fossil Plants
6. Closed Cooling Water Chemistry Guideline: Revision 2
7. Comprehensive Cycle Chemistry Guidelines for Combined Cycle/Heat Recovery Steam Generators (HRSGs)
8. Cycling, Startup, Shutdown, and Layup Fossil Plant Cycle Chemistry Guidelines for Operators and Chemists
9. Condensate Polishing Guidelines: Ammonium Form Operation
10. Monitoring Cycle Water Chemistry in Fossil Plants: Volumes 1-3: Volumes 1-3
11. Guidelines for Chemical Cleaning of Conventional Fossil Plant Equipment
