Dear BornToSin
the Linlk of post #33 is not working ,
Please reupload again
thank you in advance
Dear BornToSin
more:
Steam Generator Reference Book
Enhanced Reliability Of Replacement Feedwater Heaters
Valve Application, Maintenance and Repair Guide (In Situ State-of-the-Art Valve Welding Repair) (Gate, Globe, & Check Valves), Volume 2
State-of-the-Art Weld Repair Technology for Rotating Components Volume 1: Weld Repair of Steam Turbine Discs andRotors
Proceedings: Welding And Repair Technology For Power Plants - Second International Cnference
On-Line Welding Repair for Leaking Pipe Components
Guideline To Underwater Welding To Achieve Exceptable Ferrite Number For Stainless Steels
Turbine Steam Path Damage: Theory and Practice
Machine Welding Equipment for In Situ Piping Installation and RepairsVolume 1: Turbine Fundamentals
Influence of Irradiation and Stress/Strain on the In-Reactor Behavior of High Purity Stainless Steels & Ni-Based Alloys
Weld Overlay On Waterwall Tubing, Alternative Materials And Distortion
1998 Repair & Replacement Applications Center – Product Report
Non-Destructive Evaluation of the Oyster Creek Top Guide Samples
Vibration Fatigue Testing Of Socket Welds
Resource Guide For Technology Transfer To The Pulp And Paper Industry
or
Effect of Normalization and Temper Heat Treatment on P91 Weldment Properties
or
X20 CrMoV12-1 Steel Handbook
or
EPRI Conference on 9Cr Materials Fabrication and Joining Technologies
or
Hexavalent Chromium Air Sampling Data from Welding and Steel Cutting
or
Fine BTS,
I shall prepare the Index vs Titles and share.
Dear BornToSin,
Really I have no word to appriciate your contribution. Can you please help me in finding following documents also of EPRI:-
1. EPRI- Understanding the Impact of Duct Burner Operation Outside the Original HRSG Design Limitations
2. EPRI- Field Guide: Heat Recovery Steam Generator Outage Inspection Pocket Manual
3. Boiler and Heat Recovery Steam Generator Tube Failures - Theory and Practice: Volume 1: Fundamentals, Volume 2: Water-Touched Tubes, and Volume 3: Steam-Touched Tubes
4. Field Guide: Pocket Outage Inspection Manual
5. Plant Engineering: Users Guide for the Development of Life Cycle Management Plans
6. Evaluation of Boiler and Heat Recovery Steam Generator Chemical Cleaning Waste Treatment Options
7. On-the-Job Training and Mentoring Assessment Guideline
Your valuable help is highly appriciated.
can you share these documents?
1. Evaluation of Boiler and Heat Recovery Steam Generator Chemical Cleaning Waste Treatment Options
2. Proceedings: EPRI International Conference on Corrosion in Power Plants
3. Boiler Chemical Cleaning Waste Management Manual
4. Guidelines for Makeup Water Treatment
5. Comprehensive Cycle Chemistry Guidelines for Fossil Plants
6. Closed Cooling Water Chemistry Guideline: Revision 2
7. Comprehensive Cycle Chemistry Guidelines for Combined Cycle/Heat Recovery Steam Generators (HRSGs)
8. Cycling, Startup, Shutdown, and Layup Fossil Plant Cycle Chemistry Guidelines for Operators and Chemists
9. Condensate Polishing Guidelines: Ammonium Form Operation
10. Monitoring Cycle Water Chemistry in Fossil Plants: Volumes 1-3: Volumes 1-3
11. Guidelines for Chemical Cleaning of Conventional Fossil Plant Equipment
Amazing posts
You rule!
Thanks a lot indeed
Dear BornToSin,
Really I have no words to appriciate your contribution. Can you please help me in finding this EPRI document : EPRI report 3002004969 "Best Practices to Avoid Problems during Generator Rotor Rewind."
Thanks very much
Hello,
Anybody can share following EPRI documents
1) Equipment Condition Assessment: Cost-Benefit Guidelines - Product ID: 1015085
2) Equipment Condition Assessment: Cost Benefit Methodology - Product ID: 1011824
3) Equipment Condition Assessment Modeling Guidelines - Product ID: 1010038
Thanks in advance.
