all in one file:
Weld Overlay Of Waterwall Tubing, ALternative Filler
The Use of Weld Overlays to Extend the Useful Life of Seam Welded High Energy Piping in Fossil Power Plants
P-No. 4 and P-No. 5A Temperbead Repair Using the Flux-Cored Arc Welding (FCAW) Process
Evaluation Of Solid Wire Advanced GMAW For Heavy Sections And Piping Replacement
Guide For Repair Of Thinned Piping
Advanced GMAW Process For Pipe Welding Applications
Repair of Metal Bellows - Fatigue Testing
Tack Welding Guidelines
Flue Gas Desulfurization Materials Guidelines Update - Coatings and High Alloys
Inherently Reliable Boiler Component Design
Development of Advanced Methods for Joining Low-Alloy Steels
The Use of Weld Overlays to Extend the Life of Seam Welded High Energy Piping in Fossil Power Plants
Optimal Hardness of P91 Weldments
Effects of Cold Work and Heat Treatment on the Elevated Temperature Rupture Properties of Grade 91 Material
Effect of Normalization and Temper Heat Treatment on P91 Weldment Properties
Proceedings: 11th Annual NDE Issues Meeting
New Steels for Advanced Power Plants II Phase 2: Development of Advanced 9-12 Cr Steels for Thick Section Boiler Applications
EPRI Conference on 9Cr Materials Fabrication and Joining Technologies
Productivity Improvement Handbook for Fossil Steam Power Plants: Third Edition
GENERATORS
Development of an On-Line Corrosion Advisor (OLCA)
Conference Proceedings: EPRI-RRAC Fifth International Conference on Welding and Repair Technology for Power Plants
Fan Repair Guideline
Welding Best Practices Manual for High-Risk/High-Value Repairs
PWHT Exemptions for Low Hardenability Materials
Ultrasonic Testing (UT) of Dissimilar Metal Welds (DSM) Training
GTAW Flux-Cored Wires for Open Root SS Welding
Reinstatement of Post-Weld Heat Treatment (PWHT) Exemptions for P Nos. 4 and 5A Socket Welds
Temperbead Repair Welding of Grade 91 Material
Evaluation of Filler Materials for Transition Weld Joints Between Grade 91 to Grade 22 Components
Heat Exchanger Single Tube Test Device
Effect of Cold Work and Heat Treatment on the Elevated-Temperature Rupture Properties of Grade 91 Material
Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
NDE Training Activities
Materials Handbook for Nuclear Repair Applications
Status Review of Initiation of Environmentally Assisted *****ing and Short ***** Growth
Materials Reliability Program: Selection of Materials and Fabrication of Weldments for Investigation of PWSCC Susceptibility in the Alloy 600 and 690 Weld Heat Affected Zones (MRP-161)
Flue Gas Desulfurization Systems Component Material Performance and Welding
Dissimilar Metal Weld Configuration Management Database
CoalFleet Guideline for Advanced Pulverized Coal Power Plants
The Grade 22 Low Alloy Steel Handbook
Materials Reliability Program: Technical Basis for Preemptive Weld Overlays for Alloy 82/182 Butt Welds in PWRs (MRP-169)
Topical Report Supporting an Expedited NRC Review of the Content of the Code Case needed for Dissimilar Metal Weld Overlay Repairs
The Grades 11 and 12 Low Alloy Steel Handbook
Stress Corrosion *****ing of Grade 91 Materials
Repair and Replacement Applications Center: Investigation of Thickness Limits for Post Weld Heat Treatment (PWHT) Exemption
Repair and Replacement Applications Center: Stress Corrosion *****ing in Closed Cooling Water Systems
Industrial Energy Efficient Technology Guide 2007
Repair and Replacement Applications Center: Topical Report Supporting Expedited NRC Review of Code Cases for Dissimilar Metal Weld Overlay Repairs
Nondestructive Evaluation: Dissimilar Metal Weld (DMW) Configuration Database
Carbon Steel Handbook
Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216)
Materials Reliability Program: Advanced FEA Evaluation of Growth of Postulated Circumferential PWSCC Flaws in Pressurizer Nozzle Dissimilar Metal Welds (MRP-216, Rev. 1)
Plant Support Engineering: Information for Use in Conducting Audits of Supplier Commercial Grade Item Dedication Programs
Materials Reliability Program: Inspection and Evaluation Guidelines for Reactor Vessel Bottom-Mounted Nozzles in U.S. PWR Plants (MRP-206)
Hexavalent Chromium Air Sampling Data from Welding and Steel Cutting
Nondestructive Evaluation: Guideline for Conducting Ultrasonic Examinations of Dissimilar Metal Welds
Development of a New Nickel Filler for Dissimilar Metal Welds and Repair
Handbook of Neutron Absorber Materials for Spent Nuclear Fuel Transportation and Storage Applications
Welding and Repair Technology Center: Evaluation of Post Weld Heat Treatment (PWHT) Exemption Thickness Limitations
Repair Methods for Dissimilar Metal Welds— Development, Weldability, and Properties of EPRI P87 Solid Wire Filler Metal
Materials Reliability Program: Technical Basis for Preemptive Weld Overlay for Alloy 82/182 Butt Welds in Pressurized Water Reactors (PWRs) (MRP-169) Revision 1-A
Materials Reliability Program: Welding Residual Stress Dissimilar Metal Butt-Weld
Guidelines and Specifications for High-Reliability Fossil Power Plants Best Practice Guideline for Manufacturing and Construction of Grade 91 Steel ComponentsFinite Element Modeling Handbook (MRP-317)
Program on Technology Innovation: Environmental and Health Issues Related to Radiofrequency Emissions Relationship Between Alloy Chemistry, Hardenability, and Creep Behavior of Code Case 2199 (T23)from Smart Grid Technologies
Plant Engineering: Guideline for the Acceptance of Commercial-Grade Design and Analysis Computer Programs Used in Nuclear Safety-Related Applications
Program on Technology Innovation: Manufacture of Large Nuclear and Fossil Components Using Powder Metallurgy and Hot Isostatic Processing Technologies
Materials Reliability Program: PWR Reactor Coolant System Cold-Loop Dissimilar Metal Butt Weld Reexamination Interval Extension (MRP-349)
Critical Issues Report and Roadmap for the Advanced Radiation-Resistant Materials Program
