now it's complete...and one standard changed form GER to EN version
EN ISO 4957:1999 Tool steels (ISO 4957:1999)
EN ISO 683-17:1999 Heat-treated steels, alloy steels and free-cutting steels - Part 17: Ball and roller bearing steels (ISO 683-17:1999)
EN ISO 9444-2:2010 Continuously hot-rolled stainless steel - Tolerances on dimensions and form - Part 2: Wide strip and sheet/plate (ISO 9444-2:2009)
EN ISO 9445-1:2010 Continuously cold-rolled stainless steel - Tolerances on dimensions and form - Part 1: Narrow strip and cut lengths (ISO 9445-1:2009)
EN ISO 9445-2:2010 Continuously cold-rolled stainless steel - Tolerances on dimensions and form - Part 2: Wide strip and plate/sheet (ISO 9445-2:2009)
EN 10083-1:2006 Steels for quenching and tempering - Part 1: General technical delivery conditions
EN 10083-2:2006 Steels for quenching and tempering - Part 2: Technical delivery conditions for non alloy steels
EN 10083-3:2006 Steels for quenching and tempering - Part 3: Technical delivery conditions for alloy steels
EN 10083-3:2006/AC:2008 Steels for quenching and tempering - Part 3: Technical delivery conditions for alloy steels
EN 10084:2008 Case hardening steels - Technical delivery conditions
EN 10085:2001 Nitriding steels - Technical delivery conditions
EN 10087:1998 Free-cutting steels - Technical delivery conditions for semi-finished products, hot-rolled bars and rods
EN 10088-1:2014 Stainless steels - Part 1: List of stainless steels
EN 10088-2:2014 Stainless steels - Part 2: Technical delivery conditions for sheet/plate and strip of corrosion resisting steels for general purposes
EN 10088-3:2014 Stainless steels - Part 3: Technical delivery conditions for semi-finished products, bars, rods, wire, sections and bright products of corrosion resisting steels for general purposes
EN 10088-4:2009 Stainless steels - Part 4: Technical delivery conditions for sheet/plate and strip of corrosion resisting steels for construction purposes
EN 10088-5:2009 Stainless steels - Part 5: Technical delivery conditions for bars, rods, wire, sections and bright products of corrosion resisting steels for construction purposes
EN 10089:2002 Hot-rolled steels for quenched and tempered springs - Technical delivery conditions
EN 10090:1998 Valve steels and alloys for internal combustion engines
EN 10095:1999 Heat resisting steels and nickel alloys
EN 10132-1:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 1: General
EN 10132-2:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 2: Case hardening steels
EN 10132-3:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 3: Steels for quenching and tempering
EN 10132-4:2000 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 4: Spring steels and other applications
EN 10132-4:2000/AC:2002 Cold rolled narrow steel strip for heat treatment - Technical delivery conditions - Part 4: Spring steels and other applications
EN 10151:2002 Stainless steel strip for springs - Technical delivery conditions
EN 10221:1995 Surface quality classes for hot-rolled bars and rods - Technical delivery conditions
EN 10267:1998 Ferritic-pearlitic steels for precipitation hardening from hot-working temperatures
EN 10277-1:2008 Bright steel products - Technical delivery conditions - Part 1: General
EN 10277-2:2008 Bright steel products - Technical delivery conditions - Part 2: Steels for general engineering purposes
EN 10277-3:2008 Bright steel products - Technical delivery conditions - Part 3: Free-cutting steels
EN 10277-4:2008 Bright steel products - Technical delivery conditions - Part 4: Case hardening steels
EN 10277-5:2008 Bright steel products - Technical delivery conditions - Part 5: Steels for quenching and tempering
EN 10278:1999 Dimensions and tolerances of bright steel products
EN 10302:2008 Creep resisting steels, nickel and cobalt alloys
EN 10343:2009 Steels for quenching and tempering for construction purposes - Technical delivery conditions
EN ISO 18286:2010 Hot-rolled stainless steel plates - Tolerances on dimensions and shape (ISO 18286:2008)
or
