Results 1 to 5 of 5
Thread: Tank Design
  1. Tank Design
    Hai friends,
    I am a new designer and i am now designing the the tank i found one of my friend is telling that the bottom course of the tank should have the same thickness as that of annular plate and the the thickness should should be minimum 6mm. but i could see in the API 650 it is written as 5mm as the minimum thickness can anyone help me with your knowledge.
    the help will be great thing for me.
  3. what your friend suggested was correct.. Bottom plate thickness will be same as compared with bottom shell course... refer API650 tenth edition and latest addendum..
    Quote Originally Posted by r_rajesh82 View Post
    Hai friends,
    as per api is 5mm minimum thikness and i practically see this , that the first course is 5 mm
    ramy
  6. hi friend..
    Yes.. Api mentioned 5mm as a min thk.. but that same has mentioned the min. shell course thk s 6mm.. so v shall take bot plate thkness wat u ve calculated as bot. shell course thk calculation.. Note: Bottom plate thk ll be same or greater than bot. shell couse thk..
  7. #5
    Oct 2008
    The Netherlands
    Blog Entries
    14
    annular plate could be thicker than the bottom plate.
    annular plate thickness depends on hydrotest stress and on seismic
    Bottom plate is 5 mm to which you have to add the corrosion allowance.
    If you have a tank design problem or design just send it to me.
    Same for pressure vessels, columns, heat exchangers
    No fees will be asked for..
    only to help each others, exchange information and go forward
  1. Replies: 3
    Last Post: 10-06-2011, 05:37 AM
  2. Design Skid Tank (LPG transport tank)
    By agit in forum Oil And Gas Process
    Last Post: 07-24-2011, 09:44 PM
