Page 4 of 4 FirstFirst ... 2 3 4
Results 37 to 48 of 48
Thread: Common mistakes in process design/simulation
  1. Re: Common mistakes in process design/simulation
    Invaluable information. Much appreciated. Thanks
  3. Re: Common mistakes in process design/simulation
    hi
    I had problem in the pipe phase software. when I simulating the natural gas at 715 psi and 66 deg C in the transmission line, my velocity is gradually reducing , normally as per ideal law of gas the actual volume of gas should be increase due to reduction in pressure loss. when I doing the same model with natural gas at 300 psi and 66 deg c the velocity is gradually reducing in the line due to friction loss. I am not able understand this behavior in the software, ca any one explain the solution to overcome this situation.
    with regards
    sathish kumar
  5. Re: Common mistakes in process design/simulation
    hi
    with regards
    sathish kumar
  6. #40
    Remember that any expansion of a gas normally entails a temperature reduction, at least heat transfer with the surroundings is fast enough to hold constant temperature.
  7. Re: Common mistakes in process design/simulation
  9. #42
    The conversion from SCFM to ACFM can be expressed as
    ACFM = SCFM [Pstd / (Pact - Psat Φ)](Tact / Tstd) (1)
    where
    ACFM = Actual Cubic Feet per Minute
    SCFM = Standard Cubic Feet per Minute
    Pstd = Standard absolute air pressure (psia)
    Pact = absolute pressure at the actual level (psia)
    Psat = Saturation pressure at the actual temperature (psi)
    Φ = Actual relative humidity
    Tact = Actual ambient air temperature (oR)
    Tstd = Standard temperature (oR)
    Correct ?
  10. Re: Common mistakes in process design/simulation
    Actual to standard volumes can be calculated using the Combined Gas Law:
    P1.V1/z1.T1 = P2.V2/z2.T2
  11. #44
    what does actual & standard conditions have to do with humidity?
  12. Re: Common mistakes in process design/simulation
    In my exper., gas compt until c7+ is enough for eq. Sizing but for flow assurance & compre. Will give another concern
  13. Re: Common mistakes in process design/simulation
    Yes, Agree.,
    special for Air as fluid since AIr has humidity factor that will affect the ACFM.
    Quote Originally Posted by wyb View Post
    where
    Correct ?
  14. Re: Common mistakes in process design/simulation
    Thanks bro mohamedellejmi for these useful information..
  16. #48
    Thanks for the info! I would like to share one more common mistake in simulation i.e Over specifying the simulation. It is the hardest one to identify.. Do not make the full flow sheet at once and then start converging unit operation one by one until you are quite familiar with the whole process. Instead of that make flow sheet bit by bit and make it converge step by step and proceed.
  1. Process Control Modeling, Design and Simulation
    By prabhu0487 in forum Instrumentation & Control
    Last Post: 11-17-2016, 12:36 PM
  2. Flow measurement common mistakes, corrective actions
    By ameer in forum Pipeline And Fluid Flow
    Last Post: 01-17-2012, 06:56 PM
  3. Article: Common mistakes in process design/simulation
    By mohamedellejmi in forum Home Articles
    Last Post: 05-11-2011, 04:27 AM
