Originally Posted by
cadguy
I studied the med in detail. I can summarize it as follows :
What a proper med does ? Provide the correct data to the security check routine which it is asking for. Or bypass the routine and assign the correct value to the operand and tell it to move ahead.
What this med does ? Pass through every check, return fail results in each case thereby consuming lots of time and memory. Finally redirect to run routine without flushing memory.
What may be result ? Long operation time, Momery Full, Buffer overrun, System hang up, Erroneous result.
About INCORRECT PARAMETER !
The file you saved with this med went to demo mode. Any file you save with this with transient stability or any other module which is not truely supported will go to demo mode and show that INCORRECT PARAMETER message on opening.
