Page 13 of 31 FirstFirst ... 3 11 12 13 14 15 23 ... LastLast
Results 145 to 156 of 368
Thread: Etap 12.6
  1. Re: Etap 12.6
    Dear friend
    If u made any progress plz share it with us
    Thx in advance
    Nov 2010
    Sweden
    Re: Etap 12.6
    Please share the ****** for etap 12.6
  5. Re: Etap 12.6
    Quote Originally Posted by raz View Post
    Dear raz,
    I am corresponding with "someone" in my gmail about ETAP 12.6
    He said, ETAP 11 ----- works in ETAP 12.6
    He gives me the cure ETAP 12.6 :
    He said it works on XP .. could you test Raz ?
    Instruction on that file
  6. Re: Etap 12.6
    hi sophaholic
    I tried your cure and found the following:
    1- It does not work for etap 11 at all and returns error
    2- It runs for etap 12.6 and return this activation code &nS/3QdcrsLMXKbUCMgF5&iJV?8jPqw%EMTu but still Invalid unfortunately !!
  7. Re: Etap 12.6
    Quote Originally Posted by mahfouz View Post
    hi sophaholic
    The activation code invalid ???
    Did you run on XP ? Because"he" said it works on XP
    I will tell him about an invalid activation code ..
  9. Re: Etap 12.6
    hi sophaholic
  10. #151
    Re: Etap 12.6
    Hi mahfouz
    This serial number is for etap 7.5
  11. Re: Etap 12.6
    hi sophaholic
    Yes I have two systems on my pc xp & 7 and I installed both etap 11 and etap 12.6
    And I tested your cure in both systems and results as mentioned above !!!
  12. #153
    Re: Etap 12.6
    Also I tested on win 7 it makes no scence we still needs the activation key
  13. Re: Etap 12.6
    One guys,
    Here is another solution from "him" about ETAP 12.6 :
    Follow the instruction after extraction the file ...
  14. #155
    Re: Etap 12.6
    Incredible ....... I run sophaholic method. Friend, you're great. Thank You.
  16. #156
    Nov 2010
    Sweden
    Re: Etap 12.6
    Quote Originally Posted by sophaholic View Post
    One guys,
    Thank you so much for Sharing! ETAP 12.6 is running now in Windows 8.1 64 Bits
  1. ETAP v11.0
    By surgeArrester in forum Electrical & Power Engineering
    Last Post: 08-28-2016, 01:28 PM
  2. Etap 7
  3. Need etap --------
  4. Etap 7.1
  5. Etap 7.0
