Page 7 of 12 FirstFirst ... 5 6 7 8 9 ... LastLast
Results 73 to 84 of 135
Thread: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
  1. Re: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    Worked ullwn?
    Quote Originally Posted by ullwn View Post
    Thank You for the tutorial
    Joseph
    Tried to reinstall the program, SP****** is not showing dialog box “Hardware Fingerprint ” when started. SP****** opens to the dialog window for “Machine ID “.
    Tried to delete all the installation, this is/was unsuccessful due to the fact that SPLM has captured the "Hardware Fingerprint" /ID of the PC.
    Require instructions to clean SPLM from remembering/holding the hardware fingerprint/ ID to do a clean install.
    Any advice or suggestions?
    the hardware fingerprint is a code of your pc to protect the sp****** by the cra-cker. when you registry your name and key you unlock it for your pc, and doesnt necesary to set it again, it is the reason why you dont get it when you run sp****** again
  6. #76
    Tried to install license, received SPLM dialog box "A serious problem has occured with this key: Error code: -401 Please contact Intergraph Support"
    Any advice or suggestion how to resolve this issue?
  7. Re: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    Members where is the GenMachineGUI.exe. I can't find this.
  9. #78
    If you installed SPLM look in the "Bin" file.
    Should be at your Local Drive C:/Win32App/INGR/SPLM/Bin
  10. Re: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    How to install, help me please.
    Thank a lot.
  11. Re: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    I need help too!
  12. Re: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    Thankyou Members,
    I successfully installed the PVelite 2014 on windows 8.1-64 bits. The generation of the static IP is the key to installation.
    Warm Regards
  13. Re: PVelite 2014 + ------ (Working x86 x64 windows 8.1)
    And how do i generate one static IP ? Could you tell us your step by step?
    Quote Originally Posted by Thaksen79 View Post
    Thankyou Members,
    Warm Regards
  14. #83
    Go to
    Read the details;
    "Before you start with the tutorial, make sure that you have a static ip (to generate machine ID). The steps to obtain a static ip on WIn7, Win8, Win 8.1 are as follows. first set "
  16. #84
  1. PVELITE 2013 working in WIndows 7 64-bit
    By naruto256 in forum Mechanical Engineering
    Last Post: 01-05-2017, 07:32 PM
