It worked with CardLock.
You should, on time, activate software with installation date y configure CardLock to affect all running aplications (System-Wide).
Regards,
Regards,
A little automation for this, could be done using RunAsDate. Just rar ETAPS.lck when working file has created, and then create a batch file (notepad file with .bat extension) with this:
@ ECHO OFF
cd C:\ETAP 1120
"C:\Program Files (x86)\WinRAR\UnRAR.exe" e -o+ "C:\ETAP 1120\etaps.lck.rar"
"C:\ETAP 1120\RunAsDate.exe" 17\04\2013 21:00:00 "C:\ETAP 1120\ETAPS.exe"
echo Z@8cUuS5w#nytVgCfvvccA%tDDu4jD6aNb?K
pause
Last two lines are to remeber what Activation code is if needed and las one is to avoid close the cmd window.
To run ETAP just run the batch file. No need to change dates or do something special !!!
Best regards
Thank you for sharing n I will try it.Hope it work with my pc.
Confirmed works very well with C*** LOCK. Very good app, btw.
Settings: Uncheck System-Wide; Runtime injection; CLICK ON link to make a copy to desktop; Advanced-check Normal.
Done.
I agree I have tried installing it on win8.1 32bit.. using -----lock
Sent from my GT-I9082 using Tapatalk
I did not create the batch file. It is obvious it won't work. I just did it manually.
