Page 37 of 56 FirstFirst ... 27 35 36 37 38 39 47 ... LastLast
Results 433 to 444 of 667
Thread: ETAP v11.0
  1. Re: ETAP v11.0
    don't working, change your date three months later , wait 1 minute, return date. you try open etap and say activation code has expired.
    later you has the procedure that say me and don't working.
    Etap have protection, its save the date in some application as *.dll or SQL database, i try install in a virtual machine.
    thanks a lot.
  3. Re: ETAP v11.0
    thanks a lot.
    Mar 2010
    Navalcarnero, Madrid, Spain
    Re: ETAP v11.0
    I repeat my solution from yesterday, that I have used and tested yesterday and today.
    Before to start ETAP 11, you shall to change the computer date to before April 20th, for example April 01 (or whatever). After ETAP starts, you can change again the date to the correct date.
    Have at hand the activation code (Z@8cUuS5w#nytVgCfvvccA%tDDu4jD6aNb?K) because it may be required again. If after introduce it you receive a message that the code is inavalid, please delete or rename the small file called ETAPS.lck that is located in the folder ETAP 1100 (or your ETAP 11 folder).
    I have done several tests, and the program runs sucessfully after the date is changed to the correct one. So the date in the reports is OK.
    If ETAP is closed and started again, the procedure shall be repeated.Try to use the same changed date, if not done you need to delete ETAPS.lck.
    The method using "RunAsDate" software gives random results; so I prefer to void it.
  6. #436
    Mar 2010
    Re: ETAP v11.0
  7. Re: ETAP v11.0
    you method 100% working
  9. Re: ETAP v11.0
    thansk a lot, is metod is working.
    i am grateful with you.
    The secrect is the ETAPS.lck file.
  10. Re: ETAP v11.0
  11. Re: ETAP v11.0
    Tanks~~~~
    Very good method!!!
  12. #441
    Oct 2009
    Dehli, Delhi, India, India
    Blog Entries
    1
    Re: ETAP v11.0
    Thanks Brother, But is there any permanent solution??
  13. Re: ETAP v11.0
    Quote Originally Posted by raj151857 View Post
    did anyone tried -----lock Manager?? this software is for trials and expiration dates.
  14. #443
    Did you,try it?
    Sent from my C6603 using Tapatalk
  16. Re: ETAP v11.0
    It worked with CardLock.
    You should, on time, activate software with installation date y configure CardLock to affect all running aplications (System-Wide).
    Regards,
  1. ETAP v12
    By smzakaullah in forum Electrical & Power Engineering
    Last Post: 02-20-2015, 04:19 PM
  2. Etap 7
  3. Need etap --------
  4. Etap 7.1
  5. Etap 7.0
