Results 1 to 12 of 73
Thread: ASTM Standards
Threaded View
  1. ASTM Standards
    hi
    Some ASTM Standard, may be you want them !!
    ASTM D2122-2004 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    ASTM D2122-2004-2 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2122-2004-3 : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2412-2008 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
    [link Point to another website Only the registered members can access] ASTM D2412-2008-2 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
    [link Point to another website Only the registered members can access] ASTM D2412-2008-3 : Standard Test Method for Determination of External Loading Characteristics of Plastic Pipe by Parallel-Plate Loading
    [link Point to another website Only the registered members can access] ASTM D2657-2007 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2657-2007-2 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D2657-2007-3 : Standard Practice for Heat Fusion Joining of Polyolefin Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM D3350-2008 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
    [link Point to another website Only the registered members can access] ASTM D3350-2008-2 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
    [link Point to another website Only the registered members can access] ASTM D3350-2008-3 : Standard Specification for Polyethylene Plastics Pipe and Fittings Materials
    [link Point to another website Only the registered members can access] ASTM F412-2009 : Standard Terminology Relating to Plastic Piping Systems
    [link Point to another website Only the registered members can access] ASTM F412-2009-2 : Standard Terminology Relating to Plastic Piping Systems
    [link Point to another website Only the registered members can access] ASTM F412-2009-3 : Standard Terminology Relating to Plastic Piping Systems
    [link Point to another website Only the registered members can access] ASTM F477-2008- Part 1 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
    [link Point to another website Only the registered members can access] ASTM F477-2008- Part 2 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
    [link Point to another website Only the registered members can access] ASTM F477-2008- Part 3 : Standard Specification for Elastomeric Seals (Gaskets) for Joining Plastic Pipe
    [link Point to another website Only the registered members can access] ASTM F1759-2004-Part 1 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
    [link Point to another website Only the registered members can access] ASTM F1759-2004-Part 2 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
    [link Point to another website Only the registered members can access] ASTM F1759-2004-Part 3 : Standard Practice for Design of High-Density Polyethylene (HDPE) Manholes for Subsurface Applications1
    [link Point to another website Only the registered members can access] ASTM_D_2122_(2010) : Standard Test Method for Determining Dimensions of Thermoplastic Pipe and Fittings
    [link Point to another website Only the registered members can access] ASTM_D_2466_(2013) : Standard Specification for Poly Vinyl Chloride (PVC) Plastic Pipe Fittings, Schedule 40
    [link Point to another website Only the registered members can access] ASTM_D1598_(2009) : Standard Test Method for Time-to-Failure of Plastic Pipe Under Constant Internal Pressure
    [link Point to another website Only the registered members can access] ASTM_D1784_(2011) : Standard Specification for Rigid Poly Vinyl Chloride (PVC) Compounds and Chlorinated Poly Vinyl Chloride (CPVC) Compounds
    ASTM A105
    [link Point to another website Only the registered members can access] ASTM A182:2010
    [link Point to another website Only the registered members can access] ASTM A370:2010
  1. Astm standards
    By elefank in forum Laboratory Measurements
    Last Post: 07-24-2019, 07:15 AM
  2. Replies: 13
    Last Post: 03-15-2019, 09:45 AM
  3. ASTM Standards
    By Mohamed in forum Materials Science &Corrosion
    Last Post: 06-15-2018, 12:54 AM
  4. Astm ndt standards
    By inconel in forum Mechanical Engineering
    Last Post: 10-19-2015, 04:48 AM
  5. Need the following ASTM standards
    By SA_FETY in forum Safety And Environment
    Last Post: 11-08-2011, 05:32 AM
