Thread: How to apply Nondestructive testing in Pipelines
  1. How to apply Nondestructive testing in Pipelines
    Hey Guys I want i Know how to apply Nondestructive testing in pipelines depending of the pressure or temperatures or depend of category of fluid thanks for you help
    Re: How to apply Nondestructive testing in Pipelines
    My brother, what NDT techniques do you want to apply?
    For inservice pipeline, pressure and fluid content have very small effect maybe in some cases doesn't have effect at all.
    But temperature can affect the result of inspection and in some case can broke your equipment. Why broke?
    Because many inservice pipeline usually in hot temperature condition.
    NDT techniques usually use for pipeline is UT (Conventional UT and LRUT), so we must use hot probe for hot pipeline.
  5. Re: How to apply Nondestructive testing in Pipelines
    Thanks for reply me FikYa but i was referening when i replace a new pipe of a system, so the question is What NDT can i use in case of new replacement of a piece of pipe? thats depends of what kind of service is because you have for example in API 570 Service 1 or 2 or 3 depends of the fluid systems or ASME 31.3 Fluid Type D or M or for Normal Service
  1. ASNT Nondestructive Testing (NDT) Handbooks
    By nikidragon4u in forum Mechanical Engineering
    Last Post: 04-23-2019, 03:48 AM
  2. ANSI/AWS A2.4, Symbols for Welding and Nondestructive Testing.
    By Jazz79 in forum Mechanical Engineering
    Last Post: 12-24-2016, 04:12 PM
  3. Should there be a forum specifically for Nondestructive testing?
    By jfaitak in forum Mechanical Engineering
    Last Post: 10-06-2013, 09:49 PM
  4. Introduction to Nondestructive Testing: A Training Guide
    Last Post: 01-26-2013, 07:33 PM
  5. ASNT's Nondestructive Testing Handbook series
    By Franco Vella Junior in forum Materials Science &Corrosion
    Last Post: 08-05-2011, 03:35 PM
