Page 29 of 56 FirstFirst ... 19 27 28 29 30 31 39 ... LastLast
Results 337 to 348 of 667
Thread: ETAP v11.0
  1. #337
    Re: ETAP v11.0
    Quote Originally Posted by logikal View Post
    1. Install Etap and Lic manager
    2. Stopped Lic manager in services
    3. Coppied "EtapsImt.exe" and "otisvrmsgs.dll" from ETAPSETUP/LM64SETUP/SYSTEM32/DRIVERS to \Program Files\Operation Technology Inc.
    4. Configured ECP Printer Port:
    a. Never use a interrupt
    b. Checked Enable Legacy Plug and Play detection
    c. Resources: I/O Range 03BC-03BF and I/O 07BC-07BE
    5. Restarted Lic manager in services
    6. When running ETAP the following happens:
    a. The ETAP License Path Selection pops up with the computer
    name checked
    b. If i click ok it says ETAP key search gives me the following message:
    "License Manger Server: Computer name"
    ETAP key is not found or the license manager is not ready!
    This is what i did exactly also but it does not work. Can someone kindly tell me where am i going wrong.
    You have done a small mistake. You need first of all configure the ECP printer port and after then install ETAP.
  3. Re: ETAP v11.0
    Can you explain about configure the ECP printer port?
    Thanx in advance!
  5. Re: ETAP v11.0
    Dear all
    I already installed Etap 12 & 12.5 both with the same sequenca as Etap11, with the same files but i still need the serial no. if any one have the seial No. send it to me mo.abdelslam@gmail.com
    Thank you all
  6. #340
    Re: ETAP v11.0
    Hi college Telemaco
    Please send me the m-e-d-i-c-i-n-e of Cyme 7 rev 5
  7. Re: ETAP v11.0
    Quote Originally Posted by Joule View Post
    Hi college Telemaco
    I not have the m - e - d - i - c -i - n - e of cyme 7 rev 5. Only installer
  9. Red face Re: ETAP v11.0
    Quote Originally Posted by fx007 View Post
    1. Install Etap 11 and Etaps Lic Manager.
    2. Open Control Panel -> Administative tools -> Services, stop Etaps Lic Mgr
    service.
    3. Copy *.dll and *.exe files to the \Program Files\Operation Technology Inc\
    Etap License Manager 1100\
    4. Start "Etaps Lic Mngr" service again.
    5. Try to start etaps 11, if anything is okey it will ask you activation code.
    (stop your firewall or add this service to trusted zone)
    6. Enter new activation code: Z@8cUuS5w#nytVgCfvvccA%tDDu4jD6aNb?K
    7. Enjoy.
    Thank so much for great guide
  10. Re: ETAP v11.0
    Quote Originally Posted by bdikic View Post
    Thanx in advance!
    Check older pages my friend.
    For Windows XP:
    You add the ECP printer port from Control Panel, Add Hardware. In XP you click on Yes, i connect the hardware. Then select Add a new hardware disp, at the bottom of the list. Click on Install the hardware in manual... Then select Ports (COM & LPT), and there is the infamous ECP printer port. Finally just follow fx007 intrucctions. Hope it help.
    mohad explained the process for Win 7:
    The procedure to add printer port for win7 (even laptop) is easy:
    control panel --> device manager --> select ports (com & lpt) --> in menu bar press Action --> Add legacy hardware
    --> follow instructions
  11. Re: ETAP v11.0
    Quote Originally Posted by manuel_cv View Post
    For Windows XP:
    I've followed the instruction but still get the message "ETAP key not found or License Manager is not ready!". I use win 8 64bit.
    Please send me the instruction-assistance to frans.parade@gmail.com
  12. #345
    Re: ETAP v11.0
    Dear friend telemacofinal, your repidshare link to cyme 7 doesn't seem to work (at least for me). I'm transfered to a blue screen with no download links. What am I doing wrong ?
  13. Re: ETAP v11.0
    can you please provide the link to download etap 11.
    Thanks in advance,
    nitin
  14. Re: ETAP v11.0
    Thanks in advance,
    nitin
  16. Re: ETAP v11.0
    thankyou friends
    God bless you!!
  1. ETAP v12
    By smzakaullah in forum Electrical & Power Engineering
    Last Post: 02-20-2015, 04:19 PM
  2. Etap 7
  3. Need etap --------
  4. Etap 7.1
  5. Etap 7.0
