Results 1 to 12 of 120
Thread: Heat Exchanger Design Handbook (Hemisphere Publishing) - 2300 p (Spalding, Taborek)
    Re: Heat Exchanger Design Handbook (Hemisphere Publishing) - 2300 p (Spalding, Tabore
    Here is another link on 4share. whole pdf book in 1 file.
    Hope it helps.
  2. Re: Heat Exchanger Design Handbook (Hemisphere Publishing) - 2300 p (Spalding, Tabore
    Thank you very much. Because of the two broken links in the earlier post, it was impossible to get the book complete. Your post resolves the problem ! Thanks again.
    the link not working anymore
    Quote Originally Posted by kk36 View Post
    Hope it helps.
    Hope it helps.
    Dear andinumail,
    The links in the original post (post #1) are still working fine. I have just checked them all. The links have been done in this way so that they will stay alive, and provide valuable ongoing service to the members of this forum.
    The links posted in 4shared and other places by other commenters to this thread eventually die and go away, and give a bad reputation. Please check the original links in post #1 and see for yourself. Be sure to follow the instructions carefully, and have a good day.
    Dear andinumail,
  1. Heat exchanger design handbook by t. kuppan
    By mbc.engg in forum Mechanical Engineering
    Last Post: 08-21-2014, 07:06 AM
  2. Heat Exchanger Design HandBook by T.Kuppan
    By tuatk in forum Mechanical Engineering
    Last Post: 06-29-2013, 03:31 PM
  3. Heat Exchanger Design Handbook
    By calefon in forum Oil And Gas Process
    Last Post: 06-25-2013, 12:16 AM
  4. Heat Exchanger Design Handbook
    By Mohamed in forum Oil And Gas Process
    Last Post: 01-04-2013, 03:27 PM
  5. Heat Exchanger Design Handbook
    By Jazz79 in forum Mechanical Engineering
    Last Post: 06-22-2010, 03:14 PM
