Need these code, Thanks for share sir.
Materials and Fabrication Requirements for 2-1/4/3Cr , 2 1/4Cr-1Mo-1/4V , 3Cr-1Mo, and 3Cr-1Mo-1/4VAlloy Steel Heavy Wall Pressure Vessels for High Temperature, High Pressure Hydrogen Service
API RP 934A 2nd Ed 2010.pdf 1.132 MB
I HAVE ONLY API RP 934C, API TR 943C IS NOT AVAILABLE
Materials and Fabrication Requirements for 1-1/4/3Cr Alloy Steel Heavy Wall Pressure Vessels for High Pressure Hydrogen Service Operating at below 825 deg F (441 deg C)
API RP 934-C 1st Ed 2008.pdf 1.158 MB
Thank you very much
Thanks a lot, Achmad Nur Eddin.
mas, upload lagi API 934 A. aku perlu banget. sukron suwun
Monggo untalen kabeh
Materials and Fabrication Requirements for 2-1/4Cr-1Mo & 3Cr-1Mo Steel Heavy Wall Pressure Vessels for High Temperature, High Pressure Hydrogen Service
API RP 934 1st Ed 2000.pdf 0.157 MB
Recommended Practice for Materials and Fabrication of 1¼Cr-½Mo Steel Pressure Vessels for Service above 825˚F (441˚C)
API RP 934-E 1st Ed 2008.pdf 0.163 MB
Steels for Hydrogen Service at Elevated Temperatures and Pressures in Petroleum Refineries and Petrochemical Plants
API RP 941 7th Ed 2008.pdf 0.980 MB
The Technical Basis Document for API RP 941
API TR 941-2008.pdf 4.386 MB
suwun kang
Can anyone upload API 934-C again plz?
Thnx
kang ahmad, file-e didelete kabeh, iso njaluk tulung kah di reupload utawa kirim email neng kene belonk_182@yahoo.com?
Suwun sakdurunge
Could anyone please re-upload API RP 943A,-B,-C,-D and API TR 941?
EMPLOK-EN SAIKI, MONGGOOOOO
API MATERIAL ENGINEERING PUBLICATION.rar 20.180 MB consist of :
API PUB 938 1996.pdf - An Experimental Study of Causes and Repair of -----ing of 1 1/4 Cr- 1/2Mo Steel Equipment
API Publ 937-A 2005.pdf - Study to Establish Relations for the Relative Strength of API 650 Cone Roof, Roof-to-Shell and Shell-to-Bottom Joints
API RP 571 1st Ed 2003.pdf - Damage Mechanisms Affecting Fixed Equipment in the Refining Industry
API RP 582 1st Ed 2001.pdf - Recommended Practice and Supplementary Welding Guidelines for the Chemical, Oil, and Gas Industries
API RP 934 1st Ed 2000.pdf -Materials and Fabrication Requirements for 2-1/4Cr-1Mo & 3Cr-1Mo Steel Heavy Wall Pressure Vessels for High Temperature, High Pressure Hydrogen Service
API RP 934A 2nd Ed 2010.pdf - Materials and Fabrication Requirements for 2-1/4/3Cr , 2 1/4Cr-1Mo-1/4V , 3Cr-1Mo, and 3Cr-1Mo-1/4VAlloy Steel Heavy Wall Pressure Vessels for High Temperature, High Pressure Hydrogen Service
API RP 934-C 1st Ed 2008.pdf - Materials and Fabrication Requirements for 1-1/4/3Cr Alloy Steel Heavy Wall Pressure Vessels for High Pressure Hydrogen Service Operating at below 825 deg F (441 deg C)
API RP 934-E 1st Ed 2008.pdf - Recommended Practice for Materials and Fabrication of 1¼Cr-½Mo Steel Pressure Vessels for Service above 825˚F (441˚C)
API RP 936 2nd Ed 2004.pdf -Refractory Installation Quality Control Specification—Inspection and Testing Monolithic Refractory Linings and Materials
API RP 941 7th Ed 2008.pdf - Steels for Hydrogen Service at Elevated Temperatures and Pressures in Petroleum Refineries and Petrochemical Plants
API RP 945 3rd Ed 2003.pdf - Avoiding Environmental -----ing in Amine Units
API TR 938C 2nd Ed 2011.pdf - Use of Duplex Stainless Steels in the Oil Refining Industry
API TR 941-2008.pdf - The Technical Basis Document for API RP 941
