Results 1 to 5 of 5
Thread: Pipe Flexibility Analysis
    Hi all,
    I am currently performing a pipe flexibility analysis on a piping system designed for slurry applications. I have modeled the system in CAESAR II and discovered that my pump nozzle loads exceed the pump vendor allowables. I have inserted an expansion joint with control rods. This has helped reduce some of the nozzle loads but I am still not satisfying the allowable. The piping arrangement cannot be changed to introduce flexibility loops at this time. What are some of the tricks/tools that can be used to reduce vertical in-line pump nozzle loads?
    Thanks.
    Re: Pipe Flexibility Analysis
  4. Re: Pipe Flexibility Analysis
    if you could attach the native file, I can give it a shot..
  5. Re: Pipe Flexibility Analysis
    Additionally the isometric,pump allowables and pump drawing would be required
    Thanks everyone for the offers to help. I was able to resolve the problem.
  1. ASME B31.3 Flexibility Analysis Check Sheet in excel (Spread Sheet)
    By getanasmalik in forum Engineering Spreadsheets & Presentations
    Last Post: 07-10-2019, 11:58 PM
  2. Markl, A.R.C. Piping Flexibility analysis
    By rakanandhan in forum Mechanical Engineering
    Last Post: 04-23-2016, 02:06 PM
  3. Pipe flexibility & dynamic (stress) analysis )
    By rsmyegpet in forum Pipeline And Fluid Flow
    Last Post: 07-18-2014, 05:37 PM
  4. ASME B31.3 Flexibility Analysis Check Sheet in excel (Spread Sheet)
    Last Post: 11-07-2013, 05:32 PM
  5. Hot sustained stress in Piping Flexibility Analysis
    By kakmenon in forum Pipeline And Fluid Flow
    Last Post: 08-08-2013, 07:25 AM
