Hi Friends
I am looking for fatigue analysis already set up on spread sheet, or some kind of template.
Would very much apprecaite any assistance you may provide.
Thank you in advance.![]()
Hi Friends
I would also like to see some worked examples of fatigue analysis ASME VIII div.2 , with PVelite or even hqnd calculations.
Thanks a lot
i also need it
Very simple really. Just read the Code and apply it!!!
ASME VIII DIv 1 does not include any this content. All the fatigue analysis requirements are addressed in Div 2. In addtion, the spread sheet can only do the most simple analysis, such as to identifiy if the fatigue analysis is required for a specific condition (based on condition A and B as specified in Div 2). It is imposssible to have a spread sheet performing the real fatigure analysis. I would say the most operatable software for this work, for non-FEA person, is FE-Pipe (or nozzle-pro).
Dear Members,
I need to compare ASME Section III Division 2 with Section VIII Division 2. Can someone help loading these documents!.
Thanks & regards,
rsmyegpet.
Hi can you be a little specific of what you are after, it the codes to compare which would be a long process and very challenging or you want to look at a specific sections of the 2 code. ASME III Div I and II are used for Nuclear application, and hence you should not be comparing it with ASME VIII codes.
Dear Memebers,
Kindly upload fatigue analysis guide/ code application rules as per ASME with worked out cases.
I found many useful threads on the subject are clready closed.
Thnaks in advance.
rsmyegpet
