Firstly make system analysis with different sizes by keeping constant and pressure. You can also use Pressure-Length comparison your pressure drop. Pls dont forget that when you increase pipe pressure your fluid velocity will decrease and pressure drop decrease as well. Therefore, after analysis i mentioned above, you can understand that you need extra pump or not to overcome the pressure drop to reach the wanted end pressure as you want to design. Hope it helps.
