Hi all
I'm actually need some advise from all of you to share your view and guidance to explain/ solve the following problem;
I have defined the basic reservoir parameters i.e. P* (Pr initial), skin and permeability using the Horner plot for my build-up pressure.
And at the same time, I used derivatives plot to interpret the reservoir boundary by regressing some parameters (Pr, Skin, C, K etc) until reasonable match on the history plot (rate and pressure) & derivatives plot are obtained.
I managed to get good conformance for history and derivatives plot in this case but then initial pressure, Skin and permeability are different with the parameters defined from the Horner plot.
I appreciate your advise on how to solve this problem. I tried to use the derived parameters from Horner plot but then I can not match the history plot (rate and pressure) with poor derivative matching.
Please advise..really need yr help
