Originally Posted by
vinomarky
It looks to be correct. Perhaps the problem is that you are doing the integration too coarsely?
If you fit a 5th order polynomial to viscosity, and 3rd order to Z as functions of P, then calculate the respective values at single psi increments and sum appropriately I get values that are pretty close - if you did the same via mathematical integration of the polynomials you'd probably get bang on.
Even if you use the data as given, you'd get in the ballpark
