Results 1 to 7 of 7
Thread: SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    Re: SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    The A-213 T5, it supports the 2010 Section II, Part D (METRIC) (see page 39, line 22) to 649 ° F (342.7 ° C) and tube-side heat exchanger works between 514 ° C to 626 ° F. In 2010 SECTION II, PART D (METRIC), indicated that the ASME-1 (Applicability and Max. Temperature Limits) supports this material (A-213 T5) to 342.7 ° C.
    I think you should review the design and your process variables. There excessive heat input, whose temperature is above the allowable bearing material.
    I hope this helps
    greetings brother
    The A-213 T5, it supports the 2010 Section II, Part D (METRIC) (see page 39, line 22) to 649 ° F (342.7 ° C) and tube-side heat exchanger works between 514 ° C to 626 ° C[/U]. In 2010 SECTION II, PART D (METRIC), indicated that the ASME-1 (Applicability and Max. Temperature Limits) supports this material (A-213 T5) to 342.7 ° C.
    I hope this helps
    greetings brother
  1. ISO 16812 - Shell & Tube Heat Exchanger
    By luqman in forum Mechanical Engineering
    Last Post: 02-02-2017, 05:27 PM
  2. Rating a shell and tube heat exchanger
    By chemengseliem in forum Oil And Gas Process
    Last Post: 08-16-2013, 09:15 PM
  3. Design a Tube-shell heat exchanger.
    By haih5 in forum Oil And Gas Process
    Last Post: 04-08-2013, 02:11 AM
  4. Replies: 3
    Last Post: 04-03-2013, 07:00 AM
  5. tube sealing leakage in shell & tube heat exchanger
    By amitss_sam in forum Pipeline And Fluid Flow
    Last Post: 12-10-2010, 03:38 PM
