Thread: Switch FCCU from Partiall Burn to Fulll Burn
  1. Switch FCCU from Partiall Burn to Fulll Burn
    Does anyone know if it is simple to switch a CO boiler at an FCCU from partial burn to full burn?
  2. Re: Switch FCCU from Partiall Burn to Fulll Burn
    Dear Mr. Sparsh,
    Switching of FCCU regenerator from Partial to full burn mode may call for change in MAB as the requirement of O2 increases or alternatively enriched oxygen may be used.
    Increasing air flow increases superficial velocity in regenerator cyclones, which may call for change in cyclones or dia of regenerator also. All these parameters needs to be studied and analysed carefully before planning to shift from partial to full burn mode.
  4. Re: Switch FCCU from Partiall Burn to Fulll Burn
    Medi.Ram-
    Thank you for your answer. Do you have any literature or other insight that I can research to learn more about how these parameters can affect HCN production.
    Best,
    Sparsh
    Quote Originally Posted by medis.ram View Post
    Dear Mr. Sparsh,
  1. Guide for Hot Surface that can Produce Contact Burn Injury
    By mmudassarali in forum Safety And Environment
    Last Post: 07-09-2014, 07:27 AM
  2. Burn Pit
    By joaquingon in forum Oil And Gas Process
    Last Post: 12-11-2010, 02:40 AM
