ASTM New Documents ....
Document Number Date Title
1. ASTM E1316 [37 Page(s)] ASTM E1316
2013.02.01 Standard Terminology for Nondestructive Examinations
2. ASTM C1417M [8 Page(s)] ASTM C1417M
2013.02.01 Standard Specification for Manufacture of Reinforced Concrete Sewer, Storm Drain, and Culvert Pipe for Direct Design (Metric)
3. ASTM C1479 [9 Page(s)] ASTM C1479
2013.02.01 Standard Practice for Installation of Precast Concrete Sewer, Storm Drain, and Culvert Pipe Using Standard Installations
4. ASTM C1479M [9 Page(s)] ASTM C1479M
2013.02.01 Standard Practice for Installation of Precast Concrete Sewer, Storm Drain, and Culvert Pipe Using Standard Installations (Metric)
5. ASTM C822 [5 Page(s)] ASTM C822
2013.02.01 Standard Terminology Relating to Concrete Pipe and Related Products
6. ASTM F2991 [3 Page(s)] ASTM F2991
2013.02.01 Standard Guide for Doubler Plate Repairs for Non-Classed Ship Structures
7. ASTM C76M [11 Page(s)] ASTM C76M
2013.01.15 Standard Specification for Reinforced Concrete Culvert, Storm Drain, and Sewer Pipe (Metric)
8. ASTM B152/B152M [6 Page(s)] ASTM B152/B152M
2013.01.15 Standard Specification for Copper Sheet, Strip, Plate, and Rolled Bar
9. ASTM C76 [11 Page(s)] ASTM C76
10. ASTM C506 [7 Page(s)] ASTM C506
2013.01.15 Standard Specification for Reinforced Concrete Arch Culvert, Storm Drain, and Sewer Pipe
11. ASTM C506M [7 Page(s)] ASTM C506M
2013.01.15 Standard Specification for Reinforced Concrete Arch Culvert, Storm Drain, and Sewer Pipe (Metric)
12. ASTM C507M [10 Page(s)] ASTM C507M
2013.01.15 Standard Specification for Reinforced Concrete Elliptical Culvert, Storm Drain, and Sewer Pipe (Metric)
13. ASTM C507 [9 Page(s)] ASTM C507
14. ASTM C1193 [33 Page(s)] ASTM C1193
2013.01.15 Standard Guide for Use of Joint Sealants
15. ASTM E2852 [10 Page(s)] ASTM E2852
2013.01.15 Standard Guide for Acquisition, Maintenance, Storage, and Use of Hazardous Material Detection Instrumentation
16. ASTM E647 [48 Page(s)] ASTM E647
2013.01.15 Standard Test Method for Measurement of Fatigue ----- Growth Rates
17. ASTM E1003 [3 Page(s)] ASTM E1003
2013.01.15 Standard Practice for Hydrostatic Leak Testing
18. ASTM C1104/C1104M [3 Page(s)] ASTM C1104/C1104M
2013.01.15 Standard Test Method for Determining the Water Vapor Sorption of Unfaced Mineral Fiber Insulation
19. ASTM D7521 [13 Page(s)] ASTM D7521
2013.01.15 Standard Test Method for Determination of Asbestos in Soil
20. ASTM E2735 [6 Page(s)] ASTM E2735
2013.01.15 Standard Guide for Selection of Calibrations Needed for X-ray Photoelectron Spectroscopy (XPS) Experiments
21. ASTM C1661 [26 Page(s)] ASTM C1661
2013.01.01 Standard Guide for Viewing Systems for Remotely Operated Facilities
22. ASTM C1009 [10 Page(s)] ASTM C1009
2013.01.01 Standard Guide for Establishing and Maintaining a Quality Assurance Program for Analytical Laboratories Within the Nuclear Industry
23. ASTM C1012/C1012M [8 Page(s)] ASTM C1012/C1012M
2013.01.01 Standard Test Method for Length Change of Hydraulic-Cement Mortars Exposed to a Sulfate Solution
24. ASTM C805/C805M [4 Page(s)] ASTM C805/C805M
2013.01.01 Standard Test Method for Rebound Number of Hardened Concrete
25. ASTM E1753 [5 Page(s)] ASTM E1753
2013.01.01 Standard Practice for Use of Qualitative Chemical Spot Test Kits for Detection of Lead in Dry Paint Films
26. ASTM E2750 [7 Page(s)] ASTM E2750
2013.01.01 Standard Guide for Extension of Data from Firestop Penetration System Tests Conducted in Accordance with ASTM E814
27. ASTM C42/C42M [7 Page(s)] ASTM C42/C42M
2013.01.01 Standard Test Method for Obtaining and Testing Drilled Cores and Sawed Beams of Concrete
28. ASTM C563 [4 Page(s)] ASTM C563
2013.01.01 Standard Test Method for Approximation of Optimum SO3 in Hydraulic Cement Using Compressive Strength
29. ASTM C1567 [6 Page(s)] ASTM C1567
2013.01.01 Standard Test Method for Determining the Potential Alkali-Silica Reactivity of Combinations of Cementitious Materials and Aggregate (Accelerated Mortar-Bar Method)
30. ASTM E569/E569M [5 Page(s)] ASTM E569/E569M
2013.01.01 Standard Practice for Acoustic Emission Monitoring of Structures During Controlled Stimulation
31. ASTM A1003/A1003M [8 Page(s)] ASTM A1003/A1003M
2013.01.01 Standard Specification for Steel Sheet, Carbon, Metallic-and Nonmetallic-Coated for Cold-Formed Framing Members
32. ASTM C700 [4 Page(s)] ASTM C700
2013.01.01 Standard Specification for Vitrified Clay Pipe, Extra Strength, Standard Strength, and Perforated
33. ASTM C1714/C1714M [4 Page(s)] ASTM C1714/C1714M
2013.01.01 Standard Specification for Preblended Dry Mortar Mix for Unit Masonry
34. ASTM D4647/D4647M [11 Page(s)] ASTM D4647/D4647M
2013.01.01 Standard Test Methods for Identification and Classification of Dispersive Clay Soils by the Pinhole Test
35. ASTM C833 [5 Page(s)] ASTM C833
2013.01.01 Standard Specification for Sintered (Uranium-Plutonium) Dioxide Pellets
36. ASTM C1254 [5 Page(s)] ASTM C1254
2013.01.01 Standard Test Method for Determination of Uranium in Mineral Acids by X-Ray Fluorescence
37. ASTM C1647 [3 Page(s)] ASTM C1647
2013.01.01 Standard Practice for Removal of Uranium or Plutonium, or both, for Impurity Assay in Uranium or Plutonium Materials
38. ASTM C1636 [5 Page(s)] ASTM C1636
2013.01.01 Standard Guide for the Determination of Uranium-232 in Uranium Hexafluoride
39. ASTM C809 [6 Page(s)] ASTM C809
2013.01.01 Standard Test Methods for Chemical, Mass Spectrometric, and Spectrochemical Analysis of Nuclear-Grade Aluminum Oxide and Aluminum Oxide-Boron Carbide Composite Pellets
40. ASTM D5206 [4 Page(s)] ASTM D5206
2013.01.01 Standard Test Method for Windload Resistance of Rigid Plastic Siding
41. ASTM C1637 [5 Page(s)] ASTM C1637
2013.01.01 Standard Test Method for the Determination of Impurities in Plutonium Metal: Acid Digestion and Inductively Coupled Plasma-Mass Spectroscopy (ICP-MS) Analysis
42. ASTM E2598/E2598M [8 Page(s)] ASTM E2598/E2598M
2013.01.01 Standard Practice for Acoustic Emission Examination of Cast Iron Yankee and Steam Heated Paper Dryers
43. ASTM E662 [24 Page(s)] ASTM E662
2013.01.01 Standard Test Method for Specific Optical Density of Smoke Generated by Solid Materials
44. ASTM C967 [3 Page(s)] ASTM C967
2013.01.01 Standard Specification for Uranium Ore Concentrate
45. ASTM C1731 [4 Page(s)] ASTM C1731
2013.01.01 Standard Specification for Concrete Floor Tile
46. ASTM D4208 [4 Page(s)] ASTM D4208
2013.01.01 Standard Test Method for Total Chlorine in Coal by the Oxygen Bomb Combustion/Ion Selective Electrode Method
47. ASTM B711 [6 Page(s)] ASTM B711
2013.01.01 Standard Specification for Concentric-Lay-Stranded Aluminum-Alloy Conductors, Steel Reinforced (AACSR) (6201)
48. ASTM C857 [6 Page(s)] ASTM C857
2013.01.01 Standard Practice for Minimum Structural Design Loading for Underground Precast Concrete Utility Structures
49. ASTM E2058 [30 Page(s)] ASTM E2058
2013.01.01 Standard Test Methods for Measurement of Synthetic Polymer Material Flammability Using a Fire Propagation Apparatus (FPA)
50. ASTM F2306/F2306M [7 Page(s)] ASTM F2306/F2306M
2013.01.01 Standard Specification for 12 to 60 in. [300 to 1500 mm] Annular Corrugated Profile-Wall Polyethylene (PE) Pipe and Fittings for Gravity-Flow Storm Sewer and Subsurface Drainage Applications
51. ASTM F2648/F2648M [8 Page(s)] ASTM F2648/F2648M
2013.01.01 Standard Specification for 2 to 60 inch [50 to 1500 mm] Annular Corrugated Profile Wall Polyethylene (PE) Pipe and Fittings for Land Drainage Applications
52. ASTM C109/C109M [10 Page(s)] ASTM C109/C109M
2012.12.15 Standard Test Method for Compressive Strength of Hydraulic Cement Mortars (Using 2-in. or [50-mm] Cube Specimens)
53. ASTM C535 [3 Page(s)] ASTM C535
2012.12.15 Standard Test Method for Resistance to Degradation of Large-Size Coarse Aggregate by Abrasion and Impact in the Los Angeles Machine
54. ASTM D7577 [6 Page(s)] ASTM D7577
2012.12.15 Standard Test Method for Determining the Accelerated Iron Corrosion Rating of Denatured Fuel Ethanol and Ethanol Fuel Blends
55. ASTM C618 REV A [5 Page(s)] ASTM C618 REV A
2012.12.15 Standard Specification for Coal Fly Ash and Raw or Calcined Natural Pozzolan for Use in Concrete
56. ASTM C845/C845M [3 Page(s)] ASTM C845/C845M
2012.12.15 Standard Specification for Expansive Hydraulic Cement
57. ASTM C806 [4 Page(s)] ASTM C806
2012.12.15 Standard Test Method for Restrained Expansion of Expansive Cement Mortar
58. ASTM C1384 REV A [5 Page(s)] ASTM C1384 REV A
2012.12.15 Standard Specification for Admixtures for Masonry Mortars
59. ASTM C780 REV A [14 Page(s)] ASTM C780 REV A
2012.12.15 Standard Test Method for Preconstruction and Construction Evaluation of Mortars for Plain and Reinforced Unit Masonry
60. ASTM C900 REV A [10 Page(s)] ASTM C900 REV A
2012.12.15 Standard Test Method for Pullout Strength of Hardened Concrete
61. ASTM F1055 [10 Page(s)] ASTM F1055
2012.12.15 Standard Specification for Electrofusion Type Polyethylene Fittings for Outside Diameter Controlled Polyethylene and Crosslinked Polyethylene (PEX) Pipe and Tubing
62. ASTM E2579 [5 Page(s)] ASTM E2579
2012.12.15 Standard Practice for Specimen Preparation and Mounting of Wood Products to Assess Surface Burning Characteristics
63. ASTM E1822 [24 Page(s)] ASTM E1822
2012.12.15 Standard Test Method for Fire Testing of Stacked Chairs
64. ASTM E2067 [24 Page(s)] ASTM E2067
2012.12.15 Standard Practice for Full-Scale Oxygen Consumption Calorimetry Fire Tests
65. ASTM D4526 [4 Page(s)] ASTM D4526
2012.12.15 Standard Practice for Determination of Volatiles in Polymers by Static Headspace Gas Chromatography
66. ASTM D6474 [6 Page(s)] ASTM D6474
2012.12.15 Standard Test Method for Determining Molecular Weight Distribution and Molecular Weight Averages of Polyolefins by High Temperature Gel Permeation Chromatography
67. ASTM C1403 [4 Page(s)] ASTM C1403
2012.12.15 Standard Test Method for Rate of Water Absorption of Masonry Mortars
68. ASTM E1601 [14 Page(s)] ASTM E1601
2012.12.15 Standard Practice for Conducting an Interlaboratory Study to Evaluate the Performance of an Analytical Method
69. ASTM E1266 [4 Page(s)] ASTM E1266
2012.12.15 Standard Practice for Processing Mixtures of Lime, Fly Ash, and Heavy Metal Wastes in Structural Fills and Other Construction Applications
70. ASTM E176 REV B [26 Page(s)] ASTM E176 REV B
2012.12.15 Standard Terminology of Fire Standards
71. ASTM C578 REV B [7 Page(s)] ASTM C578 REV B
2012.12.15 Standard Specification for Rigid, Cellular Polystyrene Thermal Insulation
72. ASTM D6045 [8 Page(s)] ASTM D6045
2012.12.01 Standard Test Method for Color of Petroleum Products by the Automatic Tristimulus Method
73. ASTM C192/C192M REV A [8 Page(s)] ASTM C192/C192M REV A
2012.12.01 Standard Practice for Making and Curing Concrete Test Specimens in the Laboratory
74. ASTM D1092 [9 Page(s)] ASTM D1092
2012.12.01 Standard Test Method for Measuring Apparent Viscosity of Lubricating Greases
75. ASTM D3944 [4 Page(s)] ASTM D3944
2012.12.01 Standard Test Method for Solidification Point of Petroleum Wax
76. ASTM C125 REV A [8 Page(s)] ASTM C125 REV A
2012.12.01 Standard Terminology Relating to Concrete and Concrete Aggregates
77. ASTM B708 [7 Page(s)] ASTM B708
2012.12.01 Standard Specification for Tantalum and Tantalum Alloy Plate, Sheet, and Strip
78. ASTM B365 [4 Page(s)] ASTM B365
2012.12.01 Standard Specification for Tantalum and Tantalum Alloy Rod and Wire
79. ASTM D938 [3 Page(s)] ASTM D938
2012.12.01 Standard Test Method for Congealing Point of Petroleum Waxes, Including Petrolatum
80. ASTM F136 REV A [5 Page(s)] ASTM F136 REV A
2012.12.01 Standard Specification for Wrought Titanium-6Aluminum-4Vanadium ELI (Extra Low Interstitial) Alloy for Surgical Implant Applications (UNS R56401)
81. ASTM F2245 REV D [30 Page(s)] ASTM F2245 REV D
2012.12.01 Standard Specification for Design and Performance of a Light Sport Airplane
82. ASTM B354 [4 Page(s)] ASTM B354
2012.12.01 Standard Terminology Relating to Uninsulated Metallic Electrical Conductors
83. ASTM F2972 [3 Page(s)] ASTM F2972
2012.12.01 Standard Specification for Light Sport Aircraft Manufacturer’s Quality Assurance System
84. ASTM C138/C138M REV A [4 Page(s)] ASTM C138/C138M REV A
2012.12.01 Standard Test Method for Density (Unit Weight), Yield, and Air Content (Gravimetric) of Concrete
85. ASTM D3348 [6 Page(s)] ASTM D3348
2012.12.01 Standard Test Method for Rapid Field Test for Trace Lead in Unleaded Gasoline (Colorimetric Method)
86. ASTM D5708 [9 Page(s)] ASTM D5708
2012.12.01 Standard Test Methods for Determination of Nickel, Vanadium, and Iron in Crude Oils and Residual Fuels by Inductively Coupled Plasma (ICP) Atomic Emission Spectrometry
87. ASTM D3279 [4 Page(s)] ASTM D3279
2012.12.01 Standard Test Method for n-Heptane Insolubles
88. ASTM C1064/C1064M [3 Page(s)] ASTM C1064/C1064M
2012.12.01 Standard Test Method for Temperature of Freshly Mixed Hydraulic-Cement Concrete
89. ASTM D2290 [8 Page(s)] ASTM D2290
2012.12.01 Standard Test Method for Apparent Hoop Tensile Strength of Plastic or Reinforced Plastic Pipe
90. ASTM B521 [4 Page(s)] ASTM B521
2012.12.01 Standard Specification for Tantalum and Tantalum Alloy Seamless and Welded Tubes
91. ASTM A307 [6 Page(s)] ASTM A307
2012.12.01 Standard Specification for Carbon Steel Bolts, Studs, and Threaded Rod 60 000 PSI Tensile Strength
92. ASTM D448 [3 Page(s)] ASTM D448
2012.12.01 Standard Classification for Sizes of Aggregate for Road and Bridge Construction
93. ASTM D3427 [5 Page(s)] ASTM D3427
2012.12.01 Standard Test Method for Air Release Properties of Petroleum Oils
94. ASTM C94/C94M REV A [13 Page(s)] ASTM C94/C94M REV A
2012.12.01 Standard Specification for Ready-Mixed Concrete
95. ASTM E2816 REV A [21 Page(s)] ASTM E2816 REV A
2012.12.01 Standard Test Methods for Fire Resistive Metallic HVAC Duct Systems
96. ASTM A358/A358M [8 Page(s)] ASTM A358/A358M
2012.12.01 Standard Specification for Electric-Fusion-Welded Austenitic Chromium-Nickel Stainless Steel Pipe for High-Temperature Service and General Applications
97. ASTM D6608 [3 Page(s)] ASTM D6608
2012.12.01 Standard Practice for the Identification of Trinidad Lake Asphalt in Asphalt Mixes
98. ASTM D3381/D3381M [3 Page(s)] ASTM D3381/D3381M
2012.12.01 Standard Specification for Viscosity-Graded Asphalt Cement for Use in Pavement Construction
99. ASTM D5704 REV A [19 Page(s)] ASTM D5704 REV A
2012.12.01 Standard Test Method for Evaluation of the Thermal and Oxidative Stability of Lubricating Oils Used for Manual Transmissions and Final Drive Axles
100. ASTM D7847 [5 Page(s)] ASTM D7847
2012.12.01 Standard Guide for Interlaboratory Studies for Microbiological Test Methods
internationalstandard2012@gmail.com
