HAZID is groundbreaking software technology which helps companies to identify and manage risks through the life cycle of their process plants, uniquely delivering these advantages:
- HAZID enables customers to retain the knowledge of their most experienced engineers, safety experts and operations staff as a corporate resource, building corporate memory and driving consistency and best practice
- HAZID applies this knowledge to the plant's drawings, automatically identifying many of the risks, streamlining formal safety studies (Hazop studies), leading to reduce time to market.
- HAZID incorporates a rule system, which enables designs to be checked for best practice much earlier in the design process. The later this happens, the more expensive and limited change becomes. Today, many companies leave this until the Hazop study which is arguably too late.
- HAZID helps to ensure safe Management of Change by enabling before and after scenarios to be compared
- HAZID allows better project management visibility and control through the integration of safety studies with engineering design data and systems
- HAZID enables safer operations and maintenance decision-making through access to relevant, up-to-date safety information
AZID comprises a number of modules which work together or can be sold standalone products:![]()
Features
Model Builder
Corporate knowledge
Safety relies on the knowledge and experience of senior engineers and operators. Companies are increasingly concerned about the number of staff approaching retirement. HAZID enables this knowledge to be captured as corporate memory and used to reduce risk by driving standardisation, consistency and best practice.
HAZID comes configured with over 500 equipment types fully modeled and ready to use.
Graphical modeling environment
HAZID builds a model of the plant safety from component models of equipment, instrumentation, piping components etc. A component modelling environment, driven by a graphical user interface, enables fast model creation and modification, and full WYSIWYG transparency.
State based modeling
HAZID modelling system allows multiple states to be incorporated into the safety model. This allows one safety model to be used in a variety of different plants and configurations making the creation of safety models that can fit your process portfolio fast and efficient.
Expressions
All aspects of the safety model may have data expressions attached to them. These expressions can automatically modify the behaviour of the model when it detects specified fluid and process attributes, meaning that one general model for an equipment type can reliably give the correct safety analysis results for multiple process and plant types.
Dynamic linking of Data attributes
Cause / Consequence descriptors in a safety model can have any process or fluid attribute substituted into the text during the automated safety analysis. When the safety scenario is viewed in HAZID Dataviewer the correct data for the plant is displayed allowing the user to view the results returned by the system in the context of their own process.
Fluid Editor
Configurable templates
Users can create Material Safety Data Sheets to specifically match their corporate/regulatory standards or needs.
Fluidisation
The fluids within the plant can be traced through to all areas where they may find an incompatibility with another fluid or material of construction, or likely release point.
Reactivity matrix
The system includes a fluid compatibility matrix which can check where fluids or fluids and materials of construction might combine to cause a problem and display likely reactivity consequences of any incompatibilities.
Fluid resolution
Multiple fluid streams either from data or after fluidisation by HAZID can be resolved to find the controlling or most safety critical fluid and use that as the basis for safety model.
Project Editor
Contextualization
Fast methods of changing plant configurations, such as which valves are opened and closed, running states of equipment, flow direction etc. allowing the user to quickly determine if process changes will have any adverse safety effect.
Off Page Connectors (OPC)
Automatically determines OPC connections and uses these to propagate safety issues amongst multiple P&IDs.
Instrumentation
HAZID can detect all instrument loops for the equipment and allows users to demark whether they are safety critical or not. All safeguards for the equipment can be found and displayed to the team during the safety study for consideration.
Configurations
Plant configurations can be set quickly within the system allowing non-continuous operations to be analysed by HAZID, such as Batch plant operations.
Automation
Most project setup within HAZID has been automated freeing the engineers to focus most of their time on the safety analysis.
PHA Editor
Configurable
Open structure allows you to customize templates to your company's specific guidelines. Build customizable worksheets and forms of your existing templates, as well as brand new templates, enabling you to adapt to a variety of safety and reliability methodologies
Context sensitive
Context sensitive data panels shows you the relevant data for the safety scenario. Checklists, possible safeguards and fluids are all displayed to the team as they conduct their safety study.
SIL
HAZID supports the IEC61511 SIL determination methods and allows the user to calibrate these methods with quantitative data.
Filters
All of your safety data within the HAZID system is available to the study team through various filters. Users can quickly find the data they are looking for just by starting to type the words into the PHA Editor. Different filters can be set up for people with specific functions for example the LOPA team can filter the data in seconds to have the list of scenarios for consideration or Instrumentation can filter for all instruments marked to be incorporated into the SIS.
Noding
Nodes can be created graphically directly off of the P&ID. And when a node is modified the study worksheets are automatically updated to reflect the changes.
Study views
Different levels of study views allow you to do either a coarse level or finely grained safety study using the HAZID analysis data.
Integration
HAZID comes with its own SmartPlant P&ID viewer with which users can interact with the graphical P&ID environment to highlight equipment, pipe runs, cause / consequence items and scenario paths to create a better understanding of the safety study data. Using the SmartPlant P&ID viewer users can also select Nodes and Cause – Consequence scenarios in real time directly from the P&ID which results in unprecedented data consistency throughout the project.
A high proportion of accidents are caused when changes are made to plants. Laws require companies assess the risks of the changes, but typically engineers only check the safety implications around the locality of the change, because there is not time to study the wider effects on the whole plant. They rarely consider the cumulative effects of change. HAZID helps by showing the effects of change across the whole plant, highlighting new risks introduced since the last study. The safety study can then be updated incorporating any new issues found creating an evergreen safety analysis of your plant.
http://www.hazid.com
