Results 1 to 8 of 8
Thread: Tank - Online External Floating Roof Pontoon Cutting
  1. Re: Tank - Online External Floating Roof Pontoon Cutting
    Quote Originally Posted by assos View Post
    About the flood you can use pneumatic pumps and drive the flood at the drain of the tank.
    Except these the quantity of water is not very much we talke for 20 m^3 .I do these practise many times.
    In case you have material in the pontoons there is no problem.
    My tank roof is single deck type, hence the pontoons area are not big. Tank size 172'dia. x 54' height. The space require to be cut is around 2' x 3'. I know we can do pumping continuously or depend on water content inside the pontoon to the drain. I have this is my mind. Anyhow the contractor HPWJ use mixture of sand + water. May I know where do you practise this on-stream cutting method?
    Note : HPWJ or etc. not really a concern if tank is down and HC free.
    Quote Originally Posted by nash9701 View Post
    In greece in HELLENIC PETROLEUM REFINERIES and the refinerie of Motor Oil Hellas
  4. Re: Tank - Online External Floating Roof Pontoon Cutting
    Do you have any pictures during the cutting? Can you share with me?
    regards
  1. Floating Roof Tank with COADE Tank
    By bowosumarwo in forum Mechanical Engineering
    Last Post: 05-25-2019, 01:37 PM
  2. Floating roof oil tank drawing
    By A.Venugopal in forum Mechanical Engineering
    Last Post: 07-07-2018, 04:35 PM
  3. Floating roof. Joint between pontoon and deck design
    By PINTAIUS in forum Mechanical Engineering
    Last Post: 04-08-2015, 10:27 PM
  4. External floating roof
    By DesEng in forum Mechanical Engineering
    Last Post: 01-10-2014, 09:37 AM
  5. API 650 Tank Floating Roof Design
    By mbc.engg in forum Mechanical Engineering
    Last Post: 05-29-2013, 12:56 AM
