Thanks for the nice post
all links work perfectly, however I can not install hysys as it issues an internal error of "regextn.exe" . However, I have no problems with TASC.
Hi Can any one installed this software? If so, can you explain me how did you install this software? I installed succesfully and copied license file from generator but when I open it is saying can not find license file or server not found. I am installing this one on VISTA OS.
However I have the part 52. I am uploading to rapidshre and providing the my link for 52
ASPENTECH.ASPEN.SUITE.V2006.5-MAGNiTUDE-uds.part52.rar
If anyone tell me how to install that would be great.
Thanks in advance
To Mr Jose Aguilar
I have tried to download from Megaupload that You have sent to this forum. But it is almost imposible (especially for me) to get these all since I have no membership in MegaUpload (it takes so many times to get just one part of these thing). If You don't mind Would You upload them once more in 4shared. Thanks
I can install program (Aspen hysys, Aspen plus) but can not use due to license error. Anyone can help me. The error dialog as per below
-------------- SLM Common Error Dialog ---------------
Application: hysys.exe
--------------- Information Flags ---------------
Error while checking out license HYSYS_Process
--------------- Sequence of Events ---------------
Server: Local license server (NO-NET)
Bucket: default
Type: Unified License
Code: 18
Description: The license for this product or feature could not be found. Be sure you are pointing to the correct license file or the license server is configured properly
Hi, I need to do a question, well I need the aspen plus, aspen dynamics, aspen plus polymer and aspen Hysys.
Whit this *****es, can I run these programs? Because I don´t understand very well what to do. thanks
Can any one please upload link ASPENONE 2006.5 DVD2
Thank you
wen i try to run hysys 2006.5..........it gives an error about unable to find license...........plz provide the ***** which could solve the problem..........the previous ***** was meant for hysys 2006 and hence prompted an error regarding a version mismatch...........
have the same problem with hysys_process license here.
anyone has been successful in running hysys using the 2006.5 *****?
Dear Mr Al hagar and any of You, I need to Install Hysys 2006.5, but when i was installing, the message apppeared "..Internal Error 2753.regextn.exe.." and then the instalation went stop.
Do You have any idea about to solve this problem
